Howdy all, just got my '81 back on the road, and I was wondering what brands/styles of insulation you've all used for heat-proofing. I'd like to buy something to insulate the floorpan and trans tunnel areas - I have some heavy duty fireproof mat, but it seems a little thick at 1/2 inch to put under carpeting.
Whats' the best? Cheapest?
I'd love to dip on down to Jeg's today and get something, but sometimes their prices are a little high - maybe there's a better place, ebay maybe?
Thanks!
I just put this under my carpet.. You will need to cut. Run it up the floorboards to the firewall. and in tran tunnel. It says it cuts with scissors, but you will need some shears.. it is pretty tough on the outerlaying.
Use 3M adhesive.
Pretty inexpensive. Keeps heat at bay.. I used to have that thing foil stuff I got when I bought the carpet kit. That stuff is garbage!!
1 roll will do your floorboards and tunnel with some left over.
I'm very happy with Refectix insulation. I was going for light weight above all else, and it works great. I did my entire inside pan and inside the tunnel above the transmission.
Thanks for all the replies so far!
I been seeing lots of pics where the dash is completely out, and the firewall can be easily covered - but what do you do when you're driving the car still? It doesn't seem like there's lots of acreage under there to maneuver around. Can I still get good protection without taking all that apart?
I was able to go up to the heater-A/C box and well under the pedals as well. In fact, I had to trim it a bit so it wouldn't show out from under the carpet. I probably could have painted it if it mattered that much to me.
