ok...im pizzed about cooling
i never had this problem with the stock fan but i never had the stock fan on my new engine! i need some advice. is it the fans? they cant seem to keep up because as it gets hotter, the fans have to keep running and blow a fuse or melt the wires. im not a fan of aluminum rads but im not opposed to them. ive even smoothed the head jackets AND the inside of my manifold and t- stat housing to ensure good flow.
HELP!!!
Now, two things come to mind that you didn't touch on. Mixture and timing. If you're mixture is lean it'll run hot, and if your timing is retarded, it'll run hot.
Check out or verify those two things.
2. As DB said, make sure the wiring is up to gauge for the load.
3. Change the termostat to both a cooler opening one AND a "Fail to Open" one. That way you know that you're not boiling your engine while the rad stays cool.
Good luck.
check the thermostat.
Get a clear glass container, a thermometer and boil some water.
Half fill container with mixture of boiling water and tepid water to get a temp around the stamped thermostat temp rating. just below temp is best.
Place the thermostat in the container, and check the temp.
slowly add boiling water to the container to raise temp gradually.
Monitor the temp as you watch the thermostat valve. It should begin to open around the temp it is rated at. By 15 deg over, it should be well and truly fully open.
You can monitor the temps on the way down as it cools too, if you wish, to verify that the thermostat does close at the appropriate temp.
A few years back, I had a brand new thermostat that refused to open, and wouldn't have believed it if I hadn't seen it.
This is a good cheap check to use before putting in a new thermostat.
Sorry OzzyTom, couldn't resist.
maybe im incorrect about vette t-stats, but any other thermostat ive ever bought has only been like 5-10 bucks... if your gonna pull it out and check it, u might as well throw in a new one anyways.. least in my opinion
If it does is the vacuum advance unit working?
Do you have full time vacuum source connected to the vacuum advance unit?
All questions should be answered yes.
HELP!!!
using the missus's new stainless steel saucepan...
Thought I'd get away with it, cept I left telltale grease marks on the cooktop and saucepan.
As I said, I've only done it that way once.
Our women are bred mean down here!
No info on your motor in your sig.
What are we talking about here?
Is it a relative stocky or is it a wild cammed race engine?
You did a recent rebuild..... what was done?
And as a previous poster noted, 200 degrees is not a big deal. Regardless, check the idle timing just to make sure it's correct, and also (I hate to admit it), I gotta agree with DB on getting your wiring situation corrected.
my t-stat is a high flow 180 deg. fail safe stat. it will run at 180 for about 20 mins. of driving and then start to creep up. it will eventually go down to 180 again if i drive at speed with no one in front of me. but if i stop at a light or drive it hard it will creep up.
right now im thinking that the fans are kicking in and staying on while its hot and are running and running....so i get a blown fuse or melted wires. so this makes me think that the fans cant keep up. these flex-a-lites also do NOT have any flapper doors for air to escape like newer fans. so should i go back to the stock fan or upgrade the electrics, or go to an aluminum rad which should not be needed and i hate spending that much money on?
When I did my efan install and even after getting my timing correct and a fail safe stat, the gauge would read like you describe. Replaced the sending unit with a "certified" one from Zip and now the gauge reads consistently.
My temp kit....use the thermometer for A/C....
