Gears?
Old Apr 22, 2008 | 08:24 AM
anderson sc's Avatar
anderson sc
Default Gears?
2nd gear and 3rd seem to be the same speed? (1974 L82 4 speed)
Can you help me with this?
Old Apr 22, 2008 | 10:34 AM
vho69's Avatar
vho69
sounds like maybe your clutch is sliping
Old Apr 22, 2008 | 11:08 AM
Jim_Harrison's Avatar
Jim_Harrison
What is the maximum speed your car can make in 2nd then 3rd gear?
Old Apr 22, 2008 | 09:24 PM
anderson sc
clutch seems ok,the speed seems the same?
Old Apr 22, 2008 | 10:35 PM
OzzyTom's Avatar
OzzyTom
your statement
"2nd gear and 3rd seem to be the same speed?" is not easily understood....
Do you mean you can only obtain the same maximum speed in either gear, but obviously at different engine rpm....
or
are you infering that the ratio seems the same in both 2nd and 3rd, and there is no difference in engine rpm at a given speed in either gear?
Old Apr 22, 2008 | 10:41 PM
OzzyTom's Avatar
OzzyTom
just read your previous thread
http://forums.corvetteforum.com/show....php?t=2001457
I think you've still got shift linkage issues.
By the way, you have NO info in your profile.
I can only assume we are dealing with a stock '74 GM 4 speed...
Or have you or previous owner fitted a different box in there.
To Gears?
