Lt1 Stalling. Why ?
Old Apr 22, 2008 | 05:35 PM
WRAITH666's Avatar
WRAITH666
Default Lt1 Stalling. Why ?
As you may or may not know, I put a '94 LT1 in my ' 76 . Up till now, it's been running great . Today, however, it decided to stall out of nowhere ! I'd come to a stop, the tach would jump all over the place and , good night ! It started but not right up . Also, it wanted to die as I was driving . I haven't checked for error codes, as I wanted to run it by you guys . Maybe this has happened to someone else ? The injectors were replaced a few months back . As I said, great running until today ! Any help and ideas are much appreciated !
Old Apr 22, 2008 | 05:48 PM
Scott Marzahl's Avatar
Scott Marzahl
Fuel Pump or MAF come to mind but you need to dump the codes, otherwise we are just wasting time guessing.
Old Apr 22, 2008 | 08:03 PM
LT4Coupe's Avatar
LT4Coupe
Optispark ?
Old Apr 22, 2008 | 09:04 PM
1981Z06Vette's Avatar
1981Z06Vette
I'm betting on the Opti...how many miles?
Old Apr 22, 2008 | 09:32 PM
RogieStone's Avatar
RogieStone
I had a friend that had the same thing going on the only code it was trowing was a anti theft code. He ended up replacing his ECU and tac filter to clean the problem up. This is after he spent a lot of money replacing the opti spark and just about every other sensor.
Old Apr 23, 2008 | 01:04 PM
Steve20's Avatar
Steve20
I vote for the Opti going south
Old Apr 23, 2008 | 01:51 PM
Solid LT1's Avatar
Solid LT1
Classic organ donor transplant rejection syndrome
Old Apr 23, 2008 | 08:04 PM
R96IMP's Avatar
R96IMP
OPTI-Happened to my 96 Impala SS
Old Apr 24, 2008 | 04:43 PM
WRAITH666's Avatar
WRAITH666
Well, guess what ? After pulling the codes, more than once, I now know the problem . Unfortunately , it was the death code ! Opti-beast is the root of the problem I replaced it once, and I'm well aware of the upcoming nightmare ! I already have one on order, along with the water pump ( didn't want to take a chance !) .
So, to all who left ideas, many thanks
Old Apr 24, 2008 | 04:55 PM
mrvette's Avatar
mrvette
Is this a full LT4 transplant, or did you put a LT1-4 mani on another engine....??? I did, on my L98 for simplicity, problem was I was NOT going to use that opti, no matter what, the largest thing was to make a dizzy pad and cut out the EGR boss/mounting , and welding in a dizzy pad cut off a olde rotted out aluminum manni.....
it works really well, with a stock L98 dizzy, now how that matches up with your computer assuming a full LT4 setup, is anyone guess, I dunno, but I suspect something needs changed....
Old Apr 26, 2008 | 06:42 PM
R96IMP's Avatar
R96IMP
Default opti
With what you are spending on the opti and the water pump you could upgrade to the DELTEQ DIS.All it is ,is a NORTHSTAR 95-99 module and coils along with some harnesses(2) and their prosessor.
If you source your own module and coils,the cost is less than 500.00 and all the opti does is give a reference signal for crank position.You will need to get some custom wires....I'd go MSD or Taylor but they do have thier own custom wires for you application.
Personally,I'd rather have 4 30-40,000 volt coils instead of 1
www.delteq.com for info.
To Lt1 Stalling. Why ?
