How long does it take to drop a differential???
Old Apr 23, 2008 | 02:51 PM
Binnie77's Avatar
Binnie77
Default How long does it take to drop a differential???
I am not sure if this is a record or not but I had my differential out and on my work bench in 43 min.
Remove differential front mount - 2 min
Remove drive shaft - 5 min
Disconnect smart struts at bracket - 5 min
Remove strut bracket from differential - 2 min
Disconnect half shafts at differential and swing the shafts down - 10 min
Remove top 6 bolts and loosen bottom 2 bolts holding differential to back cover - 5 min
Wait for oil to drain from differential - 10 min
Remove last 2 bolts and drop differential - 4 min
I will post some pics of my gear pattern with the Richmond gears. It doesn't look that bad and I have no idea where the whine was coming from. Anyway, I have an original 3.55 from a '78 to put right back in.
Old Apr 23, 2008 | 02:57 PM
Prominus's Avatar
Prominus
ummm
Old Apr 23, 2008 | 03:03 PM
Gordonm's Avatar
Gordonm
That sounds about right. I drop mine with the X member still attached. Make the install way easier. I can have it out in about the same time. Now if it is the first time out and everything is rusted add hours and lots of %#@*&%$ and skinned knuckles.
Old Apr 23, 2008 | 03:13 PM
gkull's Avatar
gkull
From day one about 20 years ago when I installed 4.11 richmond gears I had a whine on compression braking. I called richmond and they had me go through the back lash VS forward lash and it was nearly equal. I have not let it bother me since.
Old Apr 23, 2008 | 04:38 PM
Alan 71's Avatar
Alan 71
If you read killervette666's post you'll find his MOM dropped his differential in about a tenth of a second.
Regards,
Alan
Old Apr 23, 2008 | 04:41 PM
another-user's Avatar
another-user
took me about a week to get mine out. first time its been out in 39 years.
Old Apr 23, 2008 | 05:09 PM
Binnie77's Avatar
Binnie77
Regards,
Alan
Killervette666 might not find it that funny though, I am just glad he wasn't under it.
Old Apr 24, 2008 | 04:05 AM
sly vette's Avatar
sly vette
I go into the garage this morning to find the hood prop down, next thing i know i realize that the rear jackstands had been kicked out and the rear was just sitting on the floor (the front has the wheels on, im rebuilding the rear suspension) turns out my mom bumped the corvette from the back and knocked the jackstands out so the rear fell, there's no trailing arms on or strut rods or rear spring, so far i can see that the strut rod mounting bracket is bent, and the underside dual exhaust seemed to cushion the car and amazingly didnt get bent or crushed. Is it possible that there was frame damage? Anything specific I should look for? It looks as if it landed on the left exhaust pipe with the strut bracket, and the exhaust pipe caused the bracket to bend, while on the right side i think it just came to rest on the bracket and didnt bend it.
Fell from about 8-9 inches (lowest possible level on the stands)
almost had a heart attack, how worried should i be?
From another thread!!!
To How long does it take to drop a differential???
