Carb question
Old Apr 24, 2008 | 02:25 PM
ens1967's Avatar
ens1967
Default Carb question
I am restoring a 69 SB and need to replace the carb. The one on it is a Q-jet but not the original. It's a piece of @#$%. Just wondering what route I should take. Find the correct Q-jet or just go with something else.
This is a driver so numbers are not important to me.
Any specific recommendations? If so, what and where can I get it.
Thanks!
Old Apr 24, 2008 | 03:29 PM
LB66383's Avatar
LB66383
I replaced a Q-jet with a Holley spreadbore carb, and have been happy with it.
Old Apr 24, 2008 | 03:53 PM
ens1967's Avatar
ens1967
I am wondering about the vacuum connection on the carb. I was thinking that the vacuum connected to it. Is that right or I am totally off base. That's why I was asking about what the alternatives would be. Sorry for limited knowledge but I am just getting into this.
Old Apr 24, 2008 | 05:36 PM
7T1vette's Avatar
7T1vette
There is another thread on this Forum right now that speaks to the Q-jet question. A Q-jet is a Q-jet. Edelbrock made them for a while after Rochester went out of business, as they bought the business and all of the tooling. The Q-jet is a good carb...IF it is set up properly. Vacuum is generated in the intake manifold as a function of the cylinders drawing in air/fuel mixture; the ports on the carb [all carbs] are to supply that vacuum to other accessories.....power brakes, C3 wiper door & headlight system, etc. My recommendation is to get the carb you have rebuilt and set-up properly. Check out the other thread for detailed info.
Old Apr 24, 2008 | 05:39 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Just did the same with my 68 427/390. 650 Holley Spreadbore with mechanical secondaries. It is a direct bolt in with no modifications. Great carb. Great low and mid range torque. My Q-Jet was not the original carb and was not right. I feel like I bolted on 100 hp
Old Apr 25, 2008 | 09:46 AM
ens1967's Avatar
ens1967
Thanks for the info. I like the "direct bolt on with no mods" comment from capevettes.
Where can I get the best price on the 650?
One other question....you specified mechanical secondaries. Any particular reason?
Old Apr 25, 2008 | 03:43 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
I have just always liked mechanical secondaries. You never have to ask the question "are the secondaries opening" again. The answer is always YES. I bought mine from a local speed shop. You can try Summit for a good price. It also comes with vacuum secondaries if you prefer. Good luck
Old Apr 25, 2008 | 06:17 PM
dennis's Avatar
dennis
Just remember unless you have a BB or LT1 hood you won't get the stock hood to close with the holley. Long thread on this as well not long ago
Old Apr 25, 2008 | 07:00 PM
DARROW's Avatar
DARROW
Thanks!
If you deside to go with a different carb and want to get rid of the q jet let me know I like to rebuild them if there not in to bad of shape. (Still learning)
But I think you would be better off using a q jet (one that matchs your car. hollys use a lot more gas.....
Old Apr 27, 2008 | 07:25 PM
ens1967's Avatar
ens1967
Thank you Dennis!!! That was a VERY important point. You saved me. Now I am back to where I was....unsure of what to do.
Are there any direct bolt on q-jet replacement Holley carbs (or others) that would be an alternative? My 69 is a SB 350ci 350hp 4sp.
If I wanted to go back with the correct q-jet, where is a good source to buy one?
Old Apr 27, 2008 | 11:07 PM
Dave J's Avatar
Dave J
I currently have 3 '70 350/350 L46 cars. I have had very good success finding '69 7029207 (correct for '69) carbs on that auction site to fill in for 2 of my cars while I look for the correct carbs (7040207). Just do a search on 7029207 on that auction site both for sale, and completed listings to get an idea on whats out there. DO NOT buy a core that has been rebuilt. Get a good core, and send it to Lars to be rebuilt. He does fabulous work!
Old Apr 28, 2008 | 09:17 AM
ens1967's Avatar
ens1967
I got the numbers off the q-jet that is on there now. It is 7043240. I think that's a '73 Buick 455 carb.
Is this one worth spending the time and money to get it rebuilt?
Still looking for a holley/eddlebrok direct bolt on alternative if there is one.
I'll also check out that auction site to see about the correct 7029207 carb.
Old Apr 28, 2008 | 04:35 PM
LB66383's Avatar
LB66383
Holleys use a lot more gas? An engine requires X amount of gas to run. If your Holley is set up too rich, it will use more gas than a Q-jet that is set up lean........and vice versa.
Fuel mileage is much a function of how you drive than the carb you use, provided the carb is set up to work correctly with your engine.
Old Apr 28, 2008 | 04:49 PM
mdj21's Avatar
mdj21
Originally Posted by Dave J
... I have had very good success finding '69 7029207 (correct for '69) carbs on that auction site to fill in for 2 of my cars while I look for the correct carbs (7040207
What auction site?
Old Apr 29, 2008 | 09:45 AM
ens1967's Avatar
ens1967
My troubles may be over. I found the correct q-jet locally. I am going to throw it on and see how she does.
Old Apr 29, 2008 | 11:11 AM
LT2300's Avatar
LT2300
What about air cleaners? In my experience, the stock Q-J low-profile unit wouldn't fit around the Holley body, and aftermarket air cleaners sit too high, causing hood clearance problems.
Old Apr 29, 2008 | 01:31 PM
Steve20's Avatar
Steve20
ditto on the mechanical secondaries- a kick in the butt rather than a slowly progressive nudge
To Carb question
Old Apr 29, 2008 | 02:47 PM
DARROW's Avatar
DARROW
Old Apr 29, 2008 | 03:05 PM
ens1967's Avatar
ens1967
If I go back with the stock q-jet, I shouldn't have any hood clearance issues with the air cleaner, should I???????
Also, not sure what you mean by mechanical sec being a kick in the rear. I am a little slow....
Old Apr 29, 2008 | 09:29 PM
dennis's Avatar
dennis
No hood issues with a Q-jet.
The kick in the rear is more of a a lag or bog in transition from the primary to the secondaries when you mash the gas petal, seeming like acceleration IMO
The Q-jet set up properly has a nice smooth transition to the secondaries, which are vacuum operated.
