Transmission Question
Old Apr 24, 2008 | 08:18 PM
Robert B. Barwick's Avatar
Robert B. Barwick
Default Transmission Question
Hey Everyone, I have a 76L-48 Auto, problem is that the car will not shift out of gear??? Could a cloged trans filter be the cause?? The car has 92,000 original miles never been beat on.
Old Apr 24, 2008 | 08:49 PM
'75's Avatar
'75
Do you mean that the shifter won't move? Or does the car try to go after you put the shifter in park?
Old Apr 24, 2008 | 09:32 PM
Robert B. Barwick
When I drive down the street it will not shift on its own like it should.
Old Apr 24, 2008 | 09:38 PM
wombvette's Avatar
wombvette
Beyond the obvious, fluids linkages etc. First thing that you should check is the governor. It may have a bad gear or be stuck. That will usually cause it not to shift from first to second or it will just shift out into neutral.
Old Apr 24, 2008 | 11:01 PM
dannyman's Avatar
dannyman
Will it shift by manual selection, first,second, etc...?
Check modulator valve vacuum line.
Old Apr 24, 2008 | 11:30 PM
auctionman256's Avatar
auctionman256
Check Vacum Line
Old Apr 24, 2008 | 11:31 PM
smon's Avatar
smon
when is that last time you checked the level of the fluid. look at that, i had a similar problem and it was the fluid.
Old Apr 25, 2008 | 07:02 AM
Robert B. Barwick
Thank you guys, I will do and check all suggestions.
To Transmission Question
