The 72 LT1 used an 11 inch clutch. The input shaft is a 26 spline shaft. The 10.4 uses a different flywheel, disc and pressure plate. Some after,arket flywheels are drilled for both 11 and 10.4 inch.
well now you see the problem....2 say 11" and 1 says 10.4"
I wanted to buy this AC delco Clutch that is 11" and this is why I was asking without pulling out my clutch a seeing for myself.
I should have been more specific and filled in the details that are lacking in the GM parts publication. Even in 1971 they made things hard to read and I apologize.
The first listing from GM is for the HD 4 speed tranny and yes the ZR-1 optioned sp h/per car.
