Ball joint rivets
Old Apr 25, 2008 | 03:48 PM
Oldguard 7's Avatar
Oldguard 7
Default Ball joint rivets
i wish to replace the upper and lower ball joints on my vette, the lowers are worn, and i want to replace the uppers as well. My question is with the lowers, which side if the rivet do i take the air chisel to? Im thinking that you remove the rivet head that is on the outside of the a-arm. Is that correct?
Old Apr 25, 2008 | 03:57 PM
Binnie77's Avatar
Binnie77
Yes, rivet head it is.
Old Apr 25, 2008 | 04:03 PM
stinger12's Avatar
stinger12
Even if you grind the heads off the rivets, you won't be able to pull the ball joints out (I'm talking about the uppers). The reason being is because when they riveted them at the factory, the main shank of the rivet expanded inside the ball joint hole. So, what you will need to do is take the head off of the rivets, then use you air chisel between the top of the a-arm and the bottom of the ball joint to separate the two. Work your way around the bottom of the joint until it pops loose. Good luck.
Old Apr 25, 2008 | 04:08 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would classify this job as one PITA. Good luck!
Old Apr 25, 2008 | 04:38 PM
7T1vette's Avatar
7T1vette
Or....you can grind the heads [or 'tails'] off the rivets, use a punch and hammer to drive out the rivet shanks, then get a bigger hammer to drive the joint out of its A-arm.
Old Apr 25, 2008 | 04:58 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Or, if your arms are like mine, you have to take a cutting wheel on a die grinder to cut the sides of the ball joints off through the rivet holes, pry the ball joint out, then grind the rivet flat before it will finally pop out.
Old Apr 25, 2008 | 05:02 PM
Fscott's Avatar
Fscott
Definitely a PITA job. Have a cold beer on hand.
Old Apr 25, 2008 | 05:55 PM
76projectstingray's Avatar
76projectstingray
I ground the heads off, then drilled a hole in the center of the rivets about 3/8th " deep. I still had to put a punch in the hole and hammer them out.
Old Apr 26, 2008 | 12:54 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That is my method also. The rivet drills easy. I don't even grind the heads off, just center the drill and start small then step up on drill size untill it is a little smaller hole than the new rivet shank about 3/8 deep, then pop it with a punch and hammer. The head pops of and the shank drives through,
When I reinstall I have a pin out of a basement jack post i hollowed the end out on and use it in a press to crush the new rivet, with a block on head side. Rivet heads look almost the same on both sides and it was easy to remove and replace doing it this way.
Old Apr 26, 2008 | 11:51 AM
GDaina's Avatar
GDaina
Really not necessary to replace the upper ball joints as there is hardly any wear....the lowers receive all the wear and tear.
Old Apr 26, 2008 | 01:10 PM
Joe45's Avatar
Joe45
totally agree with the drilling method using a pilot drill up to a bit just inside the OD of the rivet. Anytime you can skip hammering on a control arm the better. Just takes a little time and patience.
Old Apr 26, 2008 | 01:28 PM
stinger12's Avatar
stinger12
why not use bolts to hold the joints on instead? NCRS?
Old Apr 26, 2008 | 01:50 PM
70454Convert's Avatar
70454Convert
Do you have any pics of your setup to reinstall rivets on a press? I was under the impression they had to be installed after heating r ed hotand using an air hammer.
Old Apr 26, 2008 | 01:55 PM
63mako's Avatar
63mako
No photos, but it works like a charm and looks real nice. The rivets are pretty soft steel.
Old Apr 26, 2008 | 01:57 PM
63mako's Avatar
63mako
Yes. We don't need to worry about that anymore.
Old Apr 26, 2008 | 04:36 PM
moosie982's Avatar
moosie982
Because a lot of people think you need to unecessarily spend money on these cars, hence the while I'm at it's, rear calipers bad, might as well do the fronts,,,,,,,,,"while I'm at it". Lowers bad, do the uppers too, inners bad, do the outers,,,, while I'm at it . Being a brokester, I only do whats necessary,, people frown on that. But,,,,,Peace, Moosie
Old Apr 26, 2008 | 07:01 PM
GTR1999's Avatar
GTR1999
Good point on the uppers. If they are the originals I would check to see what there is for play. The only aftermarket brand I would use is MOOG. There are a lot of cheaper joints, in both price and quality, on the market and sold in "kits"
To Ball joint rivets
Old Apr 26, 2008 | 08:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I just have the bad feeling that if I re-install a part that's 30 years old and has 80,000 miles on it, even if it appears to be OK, I'll be ripping everything apart again to replace it in 6 months.
Old Apr 27, 2008 | 02:40 PM
moosie982's Avatar
moosie982
The age and the mileage could put a different slant on things, but if they check good ? And by the way I didnt specifically mean you and this posting but in general . These friggen cars are so expensive and will put you in the poor house with just normal upkeep without looking to find things to replace "while I'm at it". Peace,,,Moosie
Old Apr 27, 2008 | 03:24 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I was just speaking in general, too...when something has that much age and mileage, and is relatively difficult to replace, my feeling is that it's best to "bite the bullet" and change it with a quality part, rather than ripping it all down again before long.
