Head Studs?
Old Apr 25, 2008 | 06:11 PM
jhuff's Avatar
jhuff
Default Head Studs?
When I bought my 400 block from my friend he had a bunch of stud kits for it that he gave me. I was wondering whether or not I should use the studs for the heads. I am mainly worried about having to take the heads off while they are in the car. It looks like the clearance would be pretty close on the drivers side. The heads are aluminum if it makes any difference.
Old Apr 25, 2008 | 06:36 PM
breathial's Avatar
breathial
I'd recommend you do NOT do it...
Head studs are a PITA, in a Vette.
Old Apr 25, 2008 | 10:09 PM
jhuff's Avatar
jhuff
ok I am going to try to track down the right head bolts then.
Would anyone know which ones to get for AFR 195 Street Heads? I was looking around and wasn't quite sure which ones to go with.
Old Apr 26, 2008 | 04:42 PM
1981Z06Vette's Avatar
1981Z06Vette
The idea of head studs is not HAVING to take the heads off to do a gasket swap...I put them in my 383 LT1, and there is far less room to work there than the relatively open bay of a C3 Vette. Besides, most ARP head studs made in recent years have an allen head, so that you can remove them just like bolts in tight spots if need be. Personally I don't use anything else.
Old Apr 26, 2008 | 06:16 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
As noted:Head Studs are problematic on C3 Vettes. Just not enough room if you have to pull a head.
Newer head studs are made with an allen (hex) socket in them so you can remove them in a pinch (in theory without removing the head first).
The whole idea for studs is that a bolt would twist while tightining, whereas the stud doesn't and therefore would provide greater clamping force, austensively for high compression racing engines. And again, with racing engines, it is expected that the assembly will be dissassembled frequently. A daily driver should not need any of these requirements for studs.
That being said, I went with studs in my 383. I guess I don't practice what I preach. But it looks real cool when the motor is apart!
Old Apr 27, 2008 | 09:32 AM
gkull's Avatar
gkull
Head studs are the only way to go! I've lost count of how many head removal & replacements I have done on my Vette
I you can't hang with the big Dogs you need to stay home!
You also need e-studs for aluminum heads. They make header mounting a brease
Old May 2, 2008 | 03:35 PM
jhuff's Avatar
jhuff
Thanks for all the help.
I decided to get some head bolts since the studs I have don't have allen keys and sell the stud kit on ebay.
If anybody wants them I'll sell them for $80 (They retail for $130 or more)
To Head Studs?
