Squeeky front end
Old Apr 28, 2008 | 04:51 PM
chadronvette's Avatar
chadronvette
Veteran: Coast Guard
Default Squeeky front end
I installed the complete Vette Brakes sport suspension. I love the way this suspension rides and she corners like no other. The problem is that it squeeks. I can't seem to find where it squeeks from but it sounds like it is coming from the new "A" arms. All the bushings are neoprene. Is there something I can put on these to stop the squeeke?
Thanks!!
Old Apr 28, 2008 | 07:01 PM
captainmorgan's Avatar
captainmorgan
Thanks!!
Did you cut the steel sleeves? You may have cut them too much. There should be a gap between the washer and the bushing.
Old Apr 28, 2008 | 08:13 PM
chadronvette
The A arms came as an assembly, I just installed them. If I spray silicone will that harm them at all?
Old Apr 28, 2008 | 11:03 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What's a neoprene bushing?
Old Apr 29, 2008 | 12:26 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
That squeak is most likely your bushings (which aren't neoprene, if you haven't caught on yet) binding, as you didn't mention greasing them during assembly with marine grade or synthetic goo having a high resistance to washout.
Old Apr 29, 2008 | 02:53 AM
AKruizer's Avatar
AKruizer
I'm just getting ready to install the same kit poly bushing from VBP, is there a particular brand of goo you'd recommend?
Old Apr 29, 2008 | 03:31 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You can't go wrong with a thorough coat of the Energy Suspension grease.
Old Apr 29, 2008 | 11:19 AM
tommyleea's Avatar
tommyleea
Make sure you have weight on the car when you tighten the control arms.
Tommy
Old Apr 29, 2008 | 01:31 PM
chadronvette
The arms came pre assembled, all I did was install them. There are no grease fittings on either end. Can they or should they be adjusted?
Old Apr 29, 2008 | 02:40 PM
Hadez's Avatar
Hadez
I have got the same problem with my arms pre-assembled from VB&P with the front monospring conversion. Its not noticeable driving on normal streets, etc. but when I have to pull into a steep driveway or go over a speed bump the front squeaks.
Old Apr 29, 2008 | 06:43 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Tommy
If the bushings are rubber. Poly can be tightened with the suspension at full droop.
Old Apr 29, 2008 | 08:21 PM
chadronvette
Ok, my bad...I used the term neoprene instead of polyurethane...either way they are synthetic bushings, not rubber and they squeak!! I just wanted to know if there was something that could be used on them or is this normal? Sounds like it is the norm.
Old Apr 29, 2008 | 09:31 PM
stinger12's Avatar
stinger12
marine grease before assembly.
Old Apr 30, 2008 | 02:56 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
No, it isn't the norm, unless the bushings aren't properly greased. Did the instructions say anything about removing the bushings and greasing before installation? My ES bushings came assembled, but the instructions said to pull them apart and grease them thoroughly before installation.
Old Apr 30, 2008 | 04:52 PM
Jay-Dog's Avatar
Jay-Dog
My experience is that this is the norm with poly bushings. Try some sillycone spray.
Old May 1, 2008 | 12:12 AM
TheSkunkWorks
NO, it's not.
Again, as the Bat correctly pointed out, this is only the "norm" if you fail to properly lube them. When poly bushings squeak they are telling you that they are binding, which is an undesirable condition. Spraying silicone at them, tho easier than doing the right thing, is not all that great a cure.
Old May 1, 2008 | 10:44 AM
chadronvette
There were no instructions with the assembly...had a hell of a time getting them in. I think I will pull them apart and grease them as per The Skunkworks word. I would hate to have to replace them again.
Thanks all
To Squeeky front end
Old May 1, 2008 | 11:47 AM
PETKAH's Avatar
PETKAH
Had the same problem with an older car - '95 - garage said to replace the struts - shade tree mechanic sprayed poly bushings with WD40 - no more noise.
Old Aug 13, 2009 | 02:29 AM
redson's Avatar
redson
I think he means polyurethane
Old Aug 13, 2009 | 08:18 AM
Paul L's Avatar
Paul L
It could be the sway bar bushings. Energy Suspension supplies a small tube of clear grease as well as grease fittings. What that grease is I do not know.
As I understand the situation, OEM rubber bushings grab the bar and twist with it as one unit. With poly the bar rotates within the bushings introducing the possibility of noise/squeaking. Hence the need for lube.
This rubber bushing was badly twisted.
This is the new Energy Suspension poly with fitting.
