How do you make a manometer
Old Apr 28, 2008 | 09:59 PM
hey_obie's Avatar
hey_obie
Default How do you make a manometer
I am trying to balance my throttle bodies. I have found several articles that talk about using a manometer and adjusting the idle so that it pulls 6" inches of water but I can not find any articles about how to make the manometer.
Can anyone point me to a post that will help me out?
Thanks,
Obie
Old Apr 28, 2008 | 10:22 PM
celeryman22's Avatar
celeryman22
Take a board mount a clear hose on the board in the shape of a U. Have one end of the hose go to the connection the other end is open to atmosphere. Fill the hose with some water or windshield washer fluid. Mark where the liquid sits as 0", measure up every inch and make a mark. Pressure will increase the water level in the hose.
Mike
Google U-tube manometer
elevatordude's Avatar
elevatordude
hope this helps
http://www.obairlann.net/reaper/moto...manometer.html
Ray
Old Apr 28, 2008 | 10:36 PM
llew71BB's Avatar
llew71BB
Man-o-meter, sounds like something used to measure your manhood
Old Apr 28, 2008 | 10:47 PM
2TONE82's Avatar
2TONE82
Check out the Crossfire Injection Vault...I use to visit this site often, and need to start hitting it again. Lots of really good info on all that is the Crossfire.
Good luck!
Old Apr 29, 2008 | 01:07 AM
MN-Brent's Avatar
MN-Brent
check it -simpson36 I believe
Old Apr 29, 2008 | 05:53 AM
hey_obie's Avatar
hey_obie
You guys are awesome. Thanks a bunch.
It looks like two designs:
Celeryman - This approach is to check one TB at time. I can handle that. First do the rear TB and then the front. The water should move 6" from the starting point.
MN-Brent - This design connects to both TB's. So the water should be even. I will try this approach after I try Celeryman's.
Old Apr 29, 2008 | 10:59 AM
MN-Brent's Avatar
MN-Brent
I think if you have one end open to atmosphere, you will suck in all the water into the throttle body and down into the engine = NO GOOD.
You must have the manometer connected across both throttle bodies (there are ports in the rears dedicated to this task) and you are looking to balance the difference between the two.
B...
Old Apr 29, 2008 | 05:02 PM
celeryman22
B...
Brent may be right, I have never tried a manometer with vacuum. However, if the manometer is tall enough and the TB only sucks 6" of water then in theory as long as the tube connected to the TB was atleast 6" above the water level it shouldn't get sucked in right???
Mike
Old Apr 29, 2008 | 05:14 PM
Double_0_7's Avatar
Double_0_7
Tape a picture of a naked woman to a ruler.
Old Apr 29, 2008 | 05:18 PM
jackson's Avatar
jackson
dwyer makes all sorts; theirs been goldstd for decades ... i.e. superflow flowbench ships w/ dwyer
http://www.dwyer-inst.com/htdocs/pre...troduction.cfm
Old Apr 29, 2008 | 06:20 PM
Dirtbuster1's Avatar
Dirtbuster1
Steve posted a thread on how to build a manometer with instructions. I guess he did not see this one.
Old Apr 29, 2008 | 09:12 PM
hey_obie's Avatar
hey_obie
I balanced them today. You do it both ways. Each throttle body is balanced to 6" difference with the line open to the atmosphere. It does not suck the water out if you connect to the Middle vacuum connection on the TB.
Then you connect the manometer to both at the same time. Then it should be level.
It is a rather cool exercise.
Thank you all for helping me out.
Obie
Old Apr 29, 2008 | 11:30 PM
Sean82's Avatar
Sean82
remember that from your zero line, you want to read 3" above.
the u in the tubing will be 3" above on one side and 3" below on the other side making a total of 6".
Old Apr 30, 2008 | 10:56 AM
bluesilver82's Avatar
bluesilver82
I just bought a digital one and called it done!
Old May 2, 2008 | 09:21 AM
simpson36's Avatar
simpson36
Guess I missed this thread.
Glad to hear you got it sorted out.
FYI for the future, heres the stuff your looking for:
http://www.thecubestudio.com/Crossfi...estoration.htm
http://www.thecubestudio.com/Crossfi...tManometer.htm
http://www.thecubestudio.com/Crossfi...yBalancing.htm
Old May 2, 2008 | 05:22 PM
2TONE82's Avatar
2TONE82
...double posting again...
To How do you make a manometer
Old May 2, 2008 | 05:23 PM
2TONE82's Avatar
2TONE82
Simpson36 - your website/pictures are a great source~ right click, save!
BTW, I've been around/working on crossfires since 1997 but never understood the bushing thing until I read your article...learning has occurred! Thanks!
Old May 2, 2008 | 05:34 PM
comp's Avatar
comp
Old May 2, 2008 | 05:41 PM
rayluka's Avatar
rayluka
First thing that came to my mind
