69 Battery replacement
Old Apr 30, 2008 | 02:01 PM
igy08's Avatar
igy08
Default 69 Battery replacement
Ok, so this is an amateur question, but better to be safe than sorry. I recently got my first corvette - a 69 convertible - and I need to replace the battery. Well, I took the old one out and then realized I didn't check the +/- terminal placement. Unfortunately, the cables aren't marked so I'm not too sure. When looking down at the battery box, I believe the negative terminal is on the right side, ie. nearest the drivers side door. Can anyone help out an amateur? Thanks.
Old Apr 30, 2008 | 02:14 PM
gve's Avatar
gve
Negative is on the drivers side
Old Apr 30, 2008 | 03:43 PM
champs65's Avatar
champs65
Old Apr 30, 2008 | 04:06 PM
Sully1882's Avatar
Sully1882
for confirmation just look under the car... the negative will be a short cable that is bolted to the cross member right behind and below where it exits the fiberglass. The positive will turn and go to the engine bay running along the top of the tranny tunnel.... goes all the way to the starter...
hth
sully
Old Apr 30, 2008 | 04:37 PM
igy08's Avatar
igy08
Great! Thanks for the help!
Old Apr 30, 2008 | 04:38 PM
A8skyhawk's Avatar
A8skyhawk
Aren't the cable ends red and black in a 69 as well making it fool proof? I can't remember right now... But I agree with the above... negative is closest to the door..
To 69 Battery replacement
