Bleeding brakes...an update.
Old Apr 30, 2008 | 05:53 PM
corvettedreamz's Avatar
corvettedreamz
8th Gear
Default Bleeding brakes...an update.
Not sure if Im supposed to carry on from last post or just post again so here is a link to my original post, http://forums.corvetteforum.com/show....php?t=2011098
Basically have replaced a couple of brake lines and need to bleed through the system. I was going to try the gravity method as I have no one who can help me right now.
I filled the MC to the top, left the top off and cracked the bleed nipple furthest from the MC, passenger rear. Connected a rubbler hose to the nipple and waited...nothing. Sucked a little on the pipe and it began to drip, then stopped. After 3 hours, nothing has happened.
I have just found a small hand held vac pump. Can I use this to suck the fluid down the lines? I guess those speed bleeders would be ideal in this situation.
Old Apr 30, 2008 | 06:21 PM
71 Green 454's Avatar
71 Green 454
I bought one of the Vacuum Brake Bleeders from Autozone and used it to bleed the brakes on my '71 and also on my 2 Mercedes. I think it works great and no potential problems of having brake fluid get on the car. Just make sure you keep the reservoir filled with BF, connect the hose to the bleed screw, get a good vacuum reading on the gauge, turn the screw and let the fluid come out and shut off the screw before the vacuum goes all the way down.
Dave
Old Apr 30, 2008 | 06:24 PM
Fuelie74's Avatar
Fuelie74
Yes you can use a vacuum bleeder. Just make sure you have some fluid in the jar before you start. Normally when I gravity bleed I will leave all four bleeders open and close them as fluid starts to come out. The order doesn't need to be followed for gravity bleeding.
Old May 1, 2008 | 02:55 PM
corvettedreamz
8th Gear
Thanks guys...
Today I started using the vac pump on the furthest caliper. Just as fluid began to flow nicely, the pump failed so I was back to gravity!!
The furthest caliper took around 3 hours of gravity to finally stop spouting air bubbles. The drivers side too about 10 seconds!!! hope Ive done it correctly. Used about 1 1/4 quarts of fluid so far.
Adjusted the emergency brake and will bleed the front tomorrow. Hopefully should be out for a run this weekend.
Old May 1, 2008 | 03:27 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Good luck!
Old May 1, 2008 | 04:47 PM
johns73's Avatar
johns73
Removing the bleeders completly helps some times.
Old May 3, 2008 | 01:32 PM
corvettedreamz
8th Gear
Why me????
Got my son to help with the bleeding again today. Decided to go for the 2 man way.
Finished bleeding the furthest rear, lots of air was still in there. Moved to the other rear and bled that down. Just as we were finishing this caliper, I heard a suck from the MC and it had run dry!!! Bled it all through again from this caliper and am hoping I wont need to remove the MC and bench bleed it.
Moved to the front...more air in this circuit than the rear? wtf?
Not sure how we managed it but the MC sucked on this one as well! Bled till I was out of fluid, just small bubbles coming now.
Funnily enough, with one caliper still to bleed completely and this one with a little air in it, the pedal feels quite good!
Back on her again tomorrow. Keep all those pinkies crossed for me!
Old May 3, 2008 | 01:49 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Sounds like you're making progress. Remember to do the inner bleeder first on the rears, then the outers. The manual says the order is driver's side first, but at least half the people that post an opinion here will say to do the passenger (farthest) side first. I doubt it makes any difference.
Old May 3, 2008 | 09:43 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Motive power bleeder. That's all I'll say!
Old May 3, 2008 | 10:35 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Old May 4, 2008 | 07:25 AM
corvettedreamz
8th Gear
Tell me about it!
Anyway, bled out the system and it seems to be good!
Small air bubbles still coming out of front but only just before pedal reached the floor....
Bled through another 2 quarts and exactly the same so gave up. Put it all back together and pedal is firm! Drove around the block a few times and brakes are working well.
Thanks all.
Old May 4, 2008 | 07:47 AM
Jud Chapin's Avatar
Jud Chapin
Congrats to you.
Old May 4, 2008 | 08:57 AM
jim2527's Avatar
jim2527
Everyone says that...I followed and ended up with a quart of fluid on the garage floor because it leaked out....
Old Jul 12, 2008 | 06:45 PM
billsfan's Avatar
billsfan
Here's a possible stupid question. All the books refer to inner and outer bleeders. The rear calipers have bleeders front and back. Which is which??
To Bleeding brakes...an update.
