crate engine question
Old Apr 30, 2008 | 10:57 PM
V-Rod's Avatar
V-Rod
Default crate engine question
I am about to install new crate engine. The oil pressure sending unit would screw in just above the filter correct. my new engine has a plugged hole at the same spot but the plug is very tight and before I put alot of pressure on it to remove just checking it I am right. I don't know why it is so tight since they ran the engine for breaking breakin may be it was hot when they screwed it in and it setup a little.
Old Apr 30, 2008 | 11:02 PM
corvette744's Avatar
corvette744
yes that is it.
Old Apr 30, 2008 | 11:13 PM
V-Rod's Avatar
V-Rod
Thanks thought so, just didn't want to force somthing out then find it was not the right hole.
To crate engine question
