AC install
Old May 1, 2008 | 07:37 AM
cajos's Avatar
cajos
Default AC install
Is it possible to install the front AC housing without removing the engine (1972, 454)?
Old May 1, 2008 | 08:19 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Not sure just what you are referring to but if your question pertains to the evaporator box, the answer is yes.
Old May 1, 2008 | 08:22 AM
cajos's Avatar
cajos
Yes evaporator box that's what I was looking for and to lazy to get the AIM. Good news thanks.
Old May 1, 2008 | 08:45 AM
Jud Chapin's Avatar
Jud Chapin
I didn't say it was easy, as it's a tight fit. Good luck!
Old May 1, 2008 | 11:24 AM
dtamustang's Avatar
dtamustang
just did mine its a 72 454, it can be done.
Old May 1, 2008 | 12:34 PM
cajos's Avatar
cajos
Any advise, tips and tricks?
Old May 1, 2008 | 02:59 PM
dtamustang's Avatar
dtamustang
you are dealing wiyh 3 big pieces, evap case, heater boxand the metal piece the blower bolts to.if your heater box is installed, leave all the hoses and cables hooked up and pull it out far enough so as little as possible is sticking through the fire wall.to do that you will need to take the metal piece off the firewall, you need all the roon you can get.once that is out of the way you can slip the evap case in ,you will also need to remove the wiper door servo and bracket. when all the pieces are in put the heater box back in place ,then the metal piece.put all the bolts and screws in but don't tighten anything up yet, the evap case should be nearly in place so just start all the bolts and the tighten everything up . don't forget to put strip caulk on all the joints,after all that work you want it sealed up good.
Old May 1, 2008 | 03:16 PM
cajos's Avatar
cajos
My current set up is a kind of DIY heater, installed by one of the previous owners.
First install the inside? I have a AC seal kit, how does strip caulk look like?
Old May 1, 2008 | 03:25 PM
Jud Chapin's Avatar
Jud Chapin
You can pick it up at Home Depot. It is small diameter caulk strips.
Old May 1, 2008 | 03:41 PM
cajos's Avatar
cajos
Just looked it up on 3M, it's in the kit. thx
Old May 1, 2008 | 03:56 PM
dtamustang's Avatar
dtamustang
take the inside loose and pull it out of the way, that gives you just enough room to slide the evap case in.once you have the outside parts in roughly the right place, put the inside piece back in , then finish the outside.
To AC install
