Fuel delivery
Old May 1, 2008 | 05:37 PM
Dantana's Avatar
Dantana
Default Fuel delivery
I've got a 670cfm Holley Street Avenger on my ZZ4 and a long way to go to get this set up right. I'd like to eliminate the rubber fuel line shortly. Anyone ever try this set up?
http://store.summitracing.com/partde...5&autoview=sku
Looks like it has everything all in one to feed into the carb - hard line, pressure gauge, filter. not crazy about that fuel presure gauge if it says "Summit" on the face but I can't read it. I kinda like the look of plumbing something similar with red/blue fittings but this is half the cost.
Old May 1, 2008 | 05:42 PM
Amelio's Avatar
Amelio
I have not used or seen that particular unit on another car, I have bought plenty of summit brand items and I have been very happy with them.
The price is right....if you like the looks I would say go for it Summit stuff is not bad at all.
Old May 2, 2008 | 08:47 PM
Dantana's Avatar
Dantana
bumpity bumpity bump
Old May 2, 2008 | 11:27 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I just installed a new Holley SA 670...and I order that exact fuel line from Summit. It will be here on Tuesday. I'll post pics once I get it installed.
Old May 3, 2008 | 12:23 AM
TimAT's Avatar
TimAT
I'm not home and I don't have the pictures with me-- I went thru this exercise and made the fuel lines from the pump to the carb- 3/8 steel brake tubing, a fistfull of -6 AN nuts and sleeves, a -6AN Tee, and the carb fittings for the Holley float bowls to -6 AN, and an inline filter. Bent all the lines flared them and then cleaned everything up. Next step is to put a rattle can clearcoat over the lines. I've also got a Demon carb I can switch with the Holley- the fuel line Tee is in the same place so it's a direct bolt on no hassle swap..
I had 4 different premade lines- 1 from Summit, 1 from Jeg's, and 2 from local parts houses. Every one leaked. I gave up. And I refuse to run a flexible line after the fuel pump. IMHO, that is asking for a BBQ.
Old May 5, 2008 | 08:59 PM
croaker's Avatar
croaker
I've been thinking about the same thing the plus for me is the fuel filter built in
Old May 6, 2008 | 08:34 AM
11Jake's Avatar
11Jake
I have used summit brand parts with good results also. I am using the summit dual feed fuel line with the gauge and it works great.
Old May 6, 2008 | 09:01 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I used that piece on a Holley 4150 and a Speed Demon carb. It's a fairly high quality adjustable piece with a bronze filter. I ran braided line and an fittings from the pump to the carb for a trouble free hookup
Old May 6, 2008 | 09:37 AM
pbcanney's Avatar
pbcanney
I put this exact carb on mine but did not use the twin feed steel line I also bought because it hit the choke hot wire.
still on rubber..........
To Fuel delivery
