? How to shorten e-brake cable
Old May 3, 2008 | 02:28 PM
Jack71's Avatar
Jack71
Default ? How to shorten e-brake cable
So I finally got my new BTO crossmember in. I guess the bracket for the emergency brake is not in the same location because I have a ~ton~ of slack in the cable now.
<<insert BTO rant here>>
So anyway, I cant adjust the cable enough under the car. So before I pull my center console... how does this cable attach the handle & is it relatively easy to eliminate a few inches at that end by recrimping it?
--Jack
Old May 4, 2008 | 06:08 AM
mdbelanger's Avatar
mdbelanger
I slipped a piece of 3/8 X 2 inch brass pipe over the threaded cable rod than applied the 2 nuts.
Old May 4, 2008 | 09:52 AM
Jack71's Avatar
Jack71
I can't picture what you're doing here ???
Old May 4, 2008 | 10:12 AM
BKbroiler's Avatar
BKbroiler
I had to reroute my cable to the top of the trailing arms for tire clearance and that made it necessary to shorten the cable. I cut the cable near the center point but on the passenger side and overlapped about 2 inches. I used two small cable clamps from Home Depot to hold the splice together. Works good.
Old May 4, 2008 | 10:17 AM
Jack71's Avatar
Jack71
Thats plan B for me!
Admittedly, I have real problem with overcomplicating projects to find the most "elegant" solution. I wish my brain would let me do that, but I'll be staring at those clamps every time I'm under the car -- which is a totally different problem.
Old May 4, 2008 | 10:44 AM
BKbroiler's Avatar
BKbroiler
I know what you mean. The good thing is, the clamps are behind the engine/trans and in front of the rear so they are not in my field of vision too often.
Old May 4, 2008 | 12:38 PM
LYLE's Avatar
LYLE
You put the pipe over the threads first and it pushes the cable forward giving you 2 inches more thread.
Old May 4, 2008 | 08:19 PM
mdbelanger's Avatar
mdbelanger
Michael.
To ? How to shorten e-brake cable
