Mallory uni-lite problems?
Old May 4, 2008 | 07:26 PM
dbeall1968's Avatar
dbeall1968
Default Mallory uni-lite problems?
Has anyone here tried a Mallory Uni-lite in place of points/condensers? I did this for reliability, performance, and wanted to keep the original look of the ignition setup. Now, after leaving the key on , it won't spark. Of course I am going to hear how bad these are, but I heard all good things from locals before I bought it. So now, what is a really good system? C'mon, let me know how stupid it was to use this Uni-lite!
Old May 4, 2008 | 08:37 PM
Roughrider's Avatar
Roughrider
The bad thing about a Unilite is not its performance or quality, but that it can blow out with a voltage spike. Maybe continuous voltage running to it when the engine is off might do the same...I don't know.
Mallory makes a voltage filter for it which, as far as I'm concerned, should either be standard equipment with it or the filter circuitry built in. Nevertheless, it sounds like that's your problem.
Basically, it's a quite good distributor, but it needs that filter. Mallory could have avoided a lot of bad rep and unhappy customers if they would build that filter in.
BTW - I missed the big cruise-in in Westminster last Sunday. I have a miserable case of bronchitis that simply won't let go. It would have been nice to meet if you had been there.
Old May 4, 2008 | 08:43 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have one in both my 61 and my 65. They run great but after about 5 years the module goes South and they cost about $125. As roughrider stated they are succeptible to voltage spikes blowing out the module. That's probably what happened to yours. The filter does help but it's still not foolproof. I replaced the modules last year in both cars after I was getting no spark. I stuck with points in my 68.
Old May 5, 2008 | 12:12 AM
chvet73's Avatar
chvet73
Get a Pertronix. Mine went years without an issue. I finally changed the ditributor out when I went to FI. With the pertronix you still look stock.
Old May 5, 2008 | 02:41 AM
rpoL98's Avatar
rpoL98
I had one years ago. just the conversion module for Chevy's. I must've "voltage spiked" it during the install. Anyways, nowadays I prefer the magnetic trigger.
Old May 5, 2008 | 09:21 AM
BB68Vett's Avatar
BB68Vett
I have the Mallory Uni-Lite conversion on my '68 for over 5 years and no problems yet (knock on wood).
Old May 5, 2008 | 09:26 AM
tommyleea's Avatar
tommyleea
I installed the uni-lite module in my 68 Z28 back in 1973. Still going strong today. I have also used Pertronix in other vehicles, with no problems so far. Cheers.
Tommy
Old May 5, 2008 | 09:47 AM
LFZ's Avatar
LFZ
I have one on my 383...it works great. I have no complaints..just make sure you get the right coil for it. I burned up 2 coils before buying the mallory coil that was recommended..might have just been coincidence??
Old May 5, 2008 | 10:30 AM
rosslato's Avatar
rosslato
i've had mine on for 15yrs n no problems what so ever
Old May 5, 2008 | 01:21 PM
Jay-Dog's Avatar
Jay-Dog
Had one on my 67 Camino. Beat the hell out of points. Makes diagnostics easier when you can hang your hat on good ignition.
Jay
Old May 5, 2008 | 01:26 PM
Kfmorgan's Avatar
Kfmorgan
I have run one for 8-10 years, without a problem, on a modified big block. Last fall when I changed engines, to a ZZ454, with aluminum heads and aluminun valve covers, I also ended up with no spark. If you have it grounded to the head, by way of the valve cover bolts, and you have iron heads, and steel valve covers, you should be all right. I ended up running the ground wire directly to the frame, and I ended up with a nice fat spark again.
Before you go out and spend the bucks for a new module, get out your multi-meter, and test the unit. The test procedure can be found on Mallory's web site, and is relatively easy to perform.
Good luck!
Old May 11, 2008 | 12:12 PM
orsting's Avatar
orsting
Cruising
I've looked for a new ignition kit for my 1969 l-46 SB, but I'm a bit confused by all the alternatives. Mallory have the Comp S/S42, Comp S/S32, the Unilite and the 75-series. All have tach-drive. Which one do I choose? I'm looking for smooth ride, tuneable and dependable. Not hi-rev racing.
Bjorn
Norway
Old May 11, 2008 | 12:33 PM
V-Twin's Avatar
V-Twin
Voltage spikes are a bad thing for many electronic components, however some are more vulnerable than others. A steady voltage can have a lot of benefits, especially for ignition systems (not only reliability but also in functioning)
Here's a nice solution, has been around for some time, hardly see people using it:
http://store.summitracing.com/partde...5&autoview=sku
Old May 11, 2008 | 12:40 PM
Les's Avatar
Les
Tommy
My experience is similar. In the mid 70's I had one failure maybe a year after I installed it on my 70 Z28 & Mallory backed it up by sending me a new module at no cost. It's been perfect ever since.
Old May 11, 2008 | 03:36 PM
corvette744's Avatar
corvette744
I have had the same one on all my big blocks-same module with the new motor.I think they work excellent-must have a ballast resistor.I think i have had this distributor for at least 15 yrs.[IMG][/IMG]Mine is a unilite comp 9000
Old May 11, 2008 | 07:40 PM
BigBlockk's Avatar
BigBlockk
I used a UniLite in my '70 LS5 for years with no problems. I used the stock resistance wire and coil for the hook up. Never had a problem with it. Installed it then forgot it was there.
BigBlockk
Later.....
Old Jun 18, 2008 | 07:02 PM
-mouse-'s Avatar
-mouse-
3rd Gear
Default unilite
I just put a unilite in my dads '66 cadillac and I can't get it to start. the top half of distributor is the same as most gm one of the time because the shaft is shorter I can't use an hei one and is it normal for the shutter gap to pass 2 to 5 degrees after rotor passes the contact in the cap. the plugs fires and the unilite test good. the distributor turns clock wise.
To Mallory uni-lite problems?
Old Jun 18, 2008 | 10:24 PM
Mike Ward's Avatar
Mike Ward
Definition of Reliability:
The probability specified that a device will perform its objective adequately, for the period of time, under the operating conditions specified.
Nope, Mallory units are not reliable. Points and condensers are.
Performance:
Nope again. These conversion POS cannot by design improve engine performance. The coil creates the spark, not the on/off switch.
Looks:
OK, one out three ain't bad.
Old Jun 19, 2008 | 07:59 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
I installed a Mallory Uni-lite distributor, mechanical advance with tach cable 5 years ago and have not had any problems. I installed a large ballast resistor too.
Here's a link to a site that offers goobs of information.
http://www.centuryperformance.com/mallory-spg-69.html
Old Jun 21, 2008 | 04:26 PM
-mouse-'s Avatar
-mouse-
3rd Gear
I have put it off a couple of days because I know I put the distributor together right and time it about right so the distributor should not have been far off and I was seeing spark and it was running before so?????? but come back to and want to find some thing else wrong and for some odd reason it stop pumping gas and it has gas in the tank, this is odd because it has a new fuel pump I put on 3 months ago and it chose now to go out weird and it is not electric
