steering
Old May 5, 2008 | 12:26 AM
anderson sc's Avatar
anderson sc
Default steering
steering box has alot of play in it(1/8 turn play), is there anything I can do to take some of the play out of it. Thank's! (74 L82 4 speed)
Old May 5, 2008 | 01:49 AM
hammadown's Avatar
hammadown
Default get it rebuilt !!!!!!!!!
Hey..... your 74 box is probably worn out,mine was (72) so I sent mine off to Gary (GTR1999) on this forum and many others. Send him a PM Heres a link to the work he does..........
http://www.vettemod.com/forum/showthread.php?t=106
Hammadown
Old May 5, 2008 | 12:31 PM
jb78L-82's Avatar
jb78L-82
Hammadown
Any tips for me on removing my 78 steering box since I want to send my box to Gary as well. Gary suggested a fork to separate the pitman arm from the balancing value but I am afraid I will damage the value. How did you separate the two?
Old May 5, 2008 | 12:33 PM
stock76's Avatar
stock76
If you haven't already, check everything else out first. Start with the rag joint. All of the steering components can contribute to a sloppy steering feel, not just the box. If everything else is ok then you can try adjusting the box. It is best done on a bench with the box out of the car using an inch pound torque wrench (0 to 30 inch/lb is most accurate for this) . If you go that far, you may as well rebuild it if necessary, or at least, replace the grease with fresh and install new seals. There are a lot of threads on how to do this. These boxes are very rugged and unless Bubba messed with it before you got the car it should be adjustable and/or rebuildable.
Best of luck.
Old May 6, 2008 | 01:00 AM
anderson sc
Thank you for your reply, yes I thought ajustment can be made. I thought I have read up on this long time ago but never had to adjust or rebuild one be for. It'll be fun to work on this, I've rebuilded everyting else but a steering box. Just need to find info. Thank you. (74 L82 4 speed)
Old May 6, 2008 | 08:00 AM
GTR1999's Avatar
GTR1999
I would use a tie rod puller over a fork. The fork will work but it will rip the boot on the CV.
Old May 8, 2008 | 03:05 PM
jb78L-82's Avatar
jb78L-82
Thanx Gary. I spoke with you about pulling it out and delivering the box in person in New Haven since I live in RI.
To steering
