Ignition Switch Wiring
Old May 5, 2008 | 10:37 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Ignition Switch Wiring
My 68 switch did not have a ground wiring going to it, but I noticed a black wire on a connector that was missing it's lead. I installed a new lead and reconnected to the harness plug. Was this correct. The black wire had a plug pigtail about 3" down the wire and I assume that is where you plug in the pigtail for the auto neutral safety switch.
I hope I'm not screwing this up, but bubba has left me a mess.
Old May 6, 2008 | 10:32 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Come on someone has to know this.
Old May 7, 2008 | 02:29 AM
DZRick's Avatar
DZRick
I might have an old harness and I do have a spare switch, I'll try to see if I can find out for you Bud. If that fails I'll see what I can find in the AIM.
Old May 7, 2008 | 08:17 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Thanks for your help.
Old May 7, 2008 | 08:28 PM
DZRick's Avatar
DZRick
Bud,
I'm sorry but I didn't have any luck finding that old harness. I was thinking of the wrong one.
I'll still try to find something in my AIM but that thing kills my eyes.
Old May 7, 2008 | 08:32 PM
DZRick's Avatar
DZRick
I just thought of something, I bet that's the ground for the light in the switch.
I'll end up getting to mine someday, I didn't know about that little light but now that I do I want the damn thing to work.
Old May 7, 2008 | 10:42 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Light work off two wires in a plastic housing. It just plugs in a hole. This was a black wire that looked like it was missing a clip on the end of it.
You can change that light in about two minutes, just remove the little corvette center plate and it's right there.
Old May 8, 2008 | 03:19 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
My best guess from looking at the AIM is that it is a switch ground for the stereo system. Noise suppression capacitor.
Old May 8, 2008 | 08:41 PM
DZRick's Avatar
DZRick
Bud, I'm glad you've got an AIM and thanks for the info on checking my ignition light.
Old May 8, 2008 | 09:57 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Tested it out tonight. Starts right up, but still no wipers...
Old May 9, 2008 | 12:13 AM
682XLR8's Avatar
682XLR8
Budman Check the **** under the steering column between the override switches. The black wire may go to that ****
To Ignition Switch Wiring
