coolant temp sensor
Old May 6, 2008 | 12:43 AM
corvette744's Avatar
corvette744
Default coolant temp sensor
Okay installed aftermarket dart heads-dont see any hole for temp sensor for my autometer guage.My stock heads had a hole on passenger side head that i used-now their is nothing.Were are you guys running aftermarket heads taping into-my sensor looks like a 3/8ths pipe thread.My intake has 4 corner outlets,but they are 1/2 inch pipe thread.My only solution i can think of is 1/2into 3/8ths reducer and stick it in the manifold.
Old May 6, 2008 | 12:50 AM
noonie's Avatar
noonie
The tstat housing for a later c3 is an ideal spot.
Old May 6, 2008 | 01:12 AM
corvette744
I just installed a chrome oring t-stat housing-any other ideas.Plus i dont think the sensor will strecth that far.
Old May 6, 2008 | 07:40 AM
Durango_Boy's Avatar
Durango_Boy
You have only the options you have already explored. You can drill and tap the head for the sender. You can use the manifold ports, using adapters, or you can use a T'stat housing with the port already drilled and tapped.
Is it a capillary tube and mechanical gauge?
Old May 6, 2008 | 07:42 AM
corvette744
Yes it is-thank's fro the info.I thought their might of been something i was missing.The thought of drilling and tapping my darts cnc heads isnt going to happen-i guess ill try the adapters if that will work.
Old May 6, 2008 | 11:43 AM
Jim71Vette's Avatar
Jim71Vette
I have a similar problem. I'm using older 2.02 heads that don't have a hole for the temp sensor. For 20 years I had a "T" fitting on the intake heater hose fitting - worked but looks like chit. Now that I have rebuilt the engine - the newer thermostat housing seems like a better option. Do you know the GM part# ?
Old May 6, 2008 | 11:53 AM
corvette744
I just got off the phone with autometer and explained my problem-get this they said they are sending me a adapter for my intake.The said use aluminium for the intake.Free say again Free.They got my bussiness.
To coolant temp sensor
