Dead Miss #1 Cylinder
77 350.Tommy
77 350.Tommy
I also agree the cap or rotor might be a problem as well.
Did you verify that the #1 intake valve fully opens? You mentioned the P/R rotating, but not valve opening. If you wiped the #1 intake lobe, you would see no real change in your vacuum reading and compression would check fine. However, you would not get enough fuel to support meaningfull combustion in that cylinder, therefore no impact by removing spark. Do you smell raw fuel in your left tail pipe?
Good luck
Avner
77 350.Tommy
Are you sure problem IS with #1 cylinder?
After running motor from cold for bit, can you detect an obvious temperature difference in the manifold exiting each cylinder....
If you have individual pipes from each port (headers) it would be easy to confirm if a particular cylinder is firing or not.
You say that "Plug looks brand new" and then say "Fire is getting to the plug"
If the plug is firing, you should see some evidence at the plug tip, maybe slight colour change on the porcelain. If it's NOT firing, then it should come out wet/oily due to NO flame and unburnt fuel. What is it?
How did you check that plug? Did you replace it with a new one, or swap it with one from another cylinder? Maybe you have a faulty batch of plugs? What are your gaps? Is the plug shorting out at the tip?
Have you tried visaully checking for spark? What happens when the plug is removed, connected to the lead, and body of plug is up against the block (grounded).... If you can see a strong spark at the plug tip when cranking the motor, then you can elimninate the dissy, the points and the cap and the plug. Wriggle the lead near each boot end and see if you lose the spark.... you could have a bad termination of the plug lead.
OR
Do any of your leads come very close to the exhaust manifolds.... you may have compromised the insulation and have a short. Check the leads at night time with motor running and see if you have any visible arcing to the block or pipes.
Sure seems strange that you can't isolate the problem.....
But then again, I had an issue with an after market alarm module with an ignition cutout relay which was intermittently creating ignition issues.
I was chasing my tail with plugs, leads, coil and HEI module before I found it
I now have a full complement of spares.Hope you sort it out.
"It is often difficult to locate a weak cylinder. A compression test, for example, will not locate a leaky intake manifold, a valve not opening properly due to a worn camshaft, or a defective spark plug.
With the cylinder balance test, the power output of one cylinder may be checked against another, using a set of grounding leads..."
PM me if you would like the entire test and an image of the grounding leads. I'll scan the section and email it to you.
Cheers,
Pete
Any hairline crack in plug not seen could cause the plug to fail under any load. If you pull the plug out it may fire but once submitted to a compression stroke it may fail.
Tommy
Tommy
Tommy
