LED tail lights and turn signals
Old Jan 3, 2002 | 09:34 PM
Shark Racer's Avatar
Shark Racer
Default Re: LED tail lights and turn signals (Larry82)
I just stared at the website for a while, looked around at different sites. Does the light still have the same broad illumination as a bulb, or is it speckled? Also, where's the turn signal flasher on our cars?
-Steve
Old Jan 3, 2002 | 09:55 PM
Wrecked82's Avatar
Wrecked82
Default Re: LED tail lights and turn signals (Pacin'California)
Once installed, you do NOT see the 15 individual LED's. They shine just like a bulb and the lens makes sure of that!
The flasher is on your fuse panel. A round thing, size of a quarter or more, just under 1" in height. Fuse panel on my 82 is on the inside firewall, just left and above brake. Find it by kneeling on ground, twisting neck up and to the left while it is below the steering wheel!
Old Jan 4, 2002 | 12:04 AM
jerryp58's Avatar
jerryp58
Larry82, thanks for this post. I think I've seen these things before, but not really thought too much about them. I've bookmarked the link and will probably get a pair. I'm not sure that I'll use them on the Corvette since I just put the bubble lights on and I think they're plenty bright (part of the reason they're on there), but the tail lights on the other vehicles I have are not terribly bright. I think I'll give them a try there.
It'd be nice if you could do some pics with one side LED & the other side incandescent.
Old Jan 4, 2002 | 01:13 AM
Paul L's Avatar
Paul L
Larry,
They are expensive. Can you get a digital pic from a friend to post? I am pretty happy with the below #1157s: $0.85. I am not being facetious, just wish to know the advantage.
[Modified by paul79, 12:33 AM 1/4/2002]
Old Jan 4, 2002 | 01:24 AM
xfactor974's Avatar
xfactor974
My god man, you could kill someone with those lights. I say go for it. :D :D
Old Jan 4, 2002 | 05:25 AM
Shark Racer
Default Re: LED tail lights and turn signals (paul79)
Gyaaaaaaaaaa. I'm gonna bite the bullet and buy them.
So much for not having credit card debt! *sigh*
-Steve
Old Jan 4, 2002 | 09:50 AM
jsimpson's Avatar
jsimpson
All these complaints about LED's being too bright are just what I wanted to hear! I'm changing all of mine to LED's! The whole IDEA of brake lights is to startle, to wake up the driver behind me and make him STOP rather than ram me because his mind was otherwise occupied! I've been hit in the rear a number of times in the last 45 years of driving - ANYTHING I can do to get through the head of the driver behind me that I am SLOWING or STOPPING is WORTH any aggravation I might provide for him as well as the responsible drivers behind me! My suggestion is that as in welding, DON'T stare at the light! :cool:
Old Jan 4, 2002 | 10:29 AM
Monkeywrench's Avatar
Monkeywrench
I missed the obvious. Have seen a few of those around. Cannot figure out how they are legal.
Caddys have them as standards now. And I will say that I was behind one the other night and was seeing two big red rectangles for several mins after he applied the brakes. Those things are BRIGHT!!!!
Old Jan 4, 2002 | 12:21 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
Default Re: LED tail lights and turn signals (Monkeywrench)
Not only are they brighter, they light up significantly faster. Even the stop lights around here are being switched over to LEDs.
Old Jul 25, 2004 | 03:19 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Larry,
You are saying you had the stock lenses, stock bulbs, and stock flasher. When you would hit the the brakes..you had the reddish orange light emit throught the stock lenses? You now replaced the stock bulbs with these l.e.d. bulbs and the color you get through you stock lens's is now much deeper red??
Did you have to change out the stock brake/turn signal flasher when you did this mod?
Once you guys change out the rear lights. And depending on the flasher answer... Correct me if I am wrong, but...isnt there a flasher for turn signals and one for hazards..or is it all in the same one? So if someone changes only the rear brake lights out with these l.e.d. lights..will they have to also change out the front and side running/signal lights in order to make an electric flasher work?
If you don't change out the front lights..will they still function the same with a electric flasher setup that is having to be used becuase of the rear brake light mod?? Sorry for so many questions guys..
Thanks in advance for the info!!! Joe!
Old Jul 25, 2004 | 08:04 AM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Old Jul 25, 2004 | 10:40 AM
81' Corvette Guy
Garandfan...are those bubbles??? Joe!
Old Jul 25, 2004 | 02:35 PM
  #33
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Originally Posted by MELVIN
Here goes my flame suit. They are bright, but are really aggravating when you are the one behind them. Ever drive up at a light, and the person in front is running them? Some are so bright, you have to squint your eyes.
Ok, sling it my way!
I agree that yes they are bright and border line obnoxious, but when faced with the choice of seeing a wadded up vette due to someone not seeing my lights or having a good car with bright lights, gimme the latter!
Old Jul 25, 2004 | 05:38 PM
  #34
garandfan's Avatar
garandfan
Nope, they are full fledged LED lights. Outer two are set as brake, turn, tail. Inner two are set as brake, tail.
Frank
Old Jul 25, 2004 | 07:14 PM
  #35
Paul L's Avatar
Paul L
Just curious. This thread started in 2001. How did it re-appear?
Old Jul 26, 2004 | 08:32 AM
  #36
migraine99's Avatar
migraine99
I must say I was hoping that the LED's would be brighter. What about reconditioning the lenses? Has anyone done that or know how to?
Old Jul 26, 2004 | 09:08 AM
  #37
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Since the forum change over, you can now reply & resurrect very old threads.
Old Jul 26, 2004 | 09:35 AM
  #38
NHvette's Avatar
NHvette
Here is a link to get LED replacement bulbs fairly cheap - about $4 each for red or yellow. They have white, too.
http://www.digikey.com/scripts/DkSea...S&Cat=31851335
Old Jul 26, 2004 | 10:12 AM
  #39
81' Corvette Guy
Do we use bayonette (sp) type bases in our 1157's????
