Best angle and car setup for installing engine.
Old May 7, 2008 | 08:45 AM
ImBatman's Avatar
ImBatman
Default Best angle and car setup for installing engine.
I will be installing my engine and TKO600 trannie as a unit shortly and am trying to determine the best jack stand position and hoist position for easily setting it in. In the past I have pulled the drivers side wheel and gone in fron the side but that takes a fair amount of jacking the motor and trannie around and I have scratched the engine bay paint and oil pan doing it this way. Is there a prefered or "easier" method and angle of attack? Jack stand positions? Floor jack? Hoist going in from front or side?
Wade
Old May 7, 2008 | 10:28 AM
nate99's Avatar
nate99
Old May 7, 2008 | 12:49 PM
76stingracer's Avatar
76stingracer
I use a hand chain hoist hanging from the joists and a motor leveler. As I pick up the motor & trans I roll the car out of the way.
Old May 7, 2008 | 01:45 PM
gyopp's Avatar
gyopp
I went in from the front with a leveler. had both front wheels off and stands on the frame behind the A-arms. The car was approx 16 inches from the floor. went from the engine stand to bolted in by myself in 30 -45 minutes without scratching anything.
Old May 7, 2008 | 02:00 PM
ImBatman's Avatar
ImBatman
Thanks guys. I am going to go in from the front this time. Last time when I went from the side I had to jack the assembly around a lot and I was by myself so that made it harder. Hopefully going straight in will be the difference. Not sure if I will have a helper this time or not. I tend to get impatient and when I am ready to do it I want to right then.
Wade
Old May 7, 2008 | 03:00 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Try a Happy Hooker?
The Happy Hooker:http://www.tpis.com/index.php?module...y=Happy+Hooker from TPIS ($55).
I bought one of these engine pullers for my 4th gen camaro but have not tried it yet. I was made to allow removing the eng from a 4th gen from above rather than dropping with the K-member out the bottom of car. It can work with any application though.
Try it and let us know how it worked.
cardo0
Old May 7, 2008 | 03:02 PM
blckslvr79's Avatar
blckslvr79
How do you guys go in from the front on these cars without a chain fall from the ceiling or a beam? No way a cherry picker will reach over the nose.
gyopp's Avatar
gyopp
Wade
I am somewhat this way Wade but I am very particular about who is leaning on my fenders so I wind up doing most myself. When I did my frame off I dissassembled the car by my self including removing the body. For reassembly a couple of very **** buddies helped me put my freshly painted body back on the chassis and hang the doors. Most of the rest I did myself.
Old May 7, 2008 | 03:03 PM
gyopp's Avatar
gyopp
Mine did without any problem
Old May 7, 2008 | 11:28 PM
69 Convertible's Avatar
69 Convertible
I bought an engine hoist at Kragen Auto and found out that it was too short to go from the front so I had to go from the side. Took off the front wheel and had it up on jack stands. Did it by myself putting it in and then pulling it out a few times. Just have to take your time. Oh, I also cut my crossmember and made it removible. That help too. I installed the TKO 600. Almost ready to fire it up. Tony
Old May 18, 2008 | 01:09 PM
pj_corvette's Avatar
pj_corvette
What kind of cherry picker did you use? We tried pulling my engine/tranny together yesterday from the front, but the cherry picker was too short. How long is the one you have?
Old May 18, 2008 | 03:29 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
The snout of the car is so long that I had to start from the drivers side, inch it forward, set it back down on the crossmember, then reposistioned the engine hoist from the front for final removal.
Radiator had to be removed too.
http://www.cardomain.com/ride/2658106/2
Old May 18, 2008 | 08:08 PM
Duke94's Avatar
Duke94
Here's what I did. Remove one front wheel and come in from the side. Didn't try it with the trannie on.
Old May 18, 2008 | 09:32 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
We put mine in from the front and took the old one out from the front.
To Best angle and car setup for installing engine.
