Side Window Removal Help Needed
Old May 8, 2008 | 12:01 PM
WillEE's Avatar
WillEE
Default Side Window Removal Help Needed
I have an '82 w/pwr windows and will need to take the glass out so that I can change the outer door weatherstrip. I have int. panel removed and I took the 2 nuts off of where glass is mounted. Now I'm not sure what to do. It's loose but the studs are still going throug the glass and holding. Do I need to push these bolts/studs out or ??? They seem to be holding in there good but maybe just from the years of weathering, etc. I don't want to force anything and brake the glass panel so thought I'd tap into others knowledge and experiences first.
Old May 8, 2008 | 12:13 PM
BKbroiler's Avatar
BKbroiler
Those studs stay in the glass. Slide the window all the way up and out. I think you have to remove some stops that limit upward travel.
Old May 8, 2008 | 12:54 PM
WillEE's Avatar
WillEE
ahhh - that makes sense now. THanks a lot and nice air on the front wheels by the way.
To Side Window Removal Help Needed
