bladder or no bladder?
Old May 8, 2008 | 06:04 PM
tjohn1008's Avatar
tjohn1008
Default bladder or no bladder?
should i install the bladder in my new fuel tank or not?it looks to be in good shape.i dont no what to do so i will ask you.pros and cons please.thanks,tj
Old May 8, 2008 | 06:47 PM
Durango_Boy's Avatar
Durango_Boy
My bladder was in bad shape so I just reinstalled my tank without it. I actually gained about a gallon of capacity, and as far as I know the bladder was just a safety item designed to help keep the fuel in the tank in the event of a rear collision. I'm okay with not having one, but others may disagree.
Old May 9, 2008 | 10:12 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Same here. I took mine out and the tank was pristine inside.
Old May 9, 2008 | 10:22 AM
Belgian1979vette's Avatar
Belgian1979vette
Is this a post 78 tank ? How did you guys take that bladder out ?
Old May 9, 2008 | 10:28 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The bladder is there for safety reasons (mandated by the Feds) in the event of a collision. A spark could ignite gas fumes and we all know how fiberglass holds up under fire. If you can, I would definitely recommend reinstalling it.
Old May 9, 2008 | 10:53 AM
stinger12's Avatar
stinger12
The OP has a 76 vette, which has a removeable rubber bladder in the tank.
Old May 10, 2008 | 08:45 AM
Durango_Boy
Originally Posted by Jud Chapin
The bladder is there for safety reasons (mandated by the Feds) in the event of a collision. A spark could ignite gas fumes.
Wouldn't this apply to every other car's gas tank, most of which are not equipped with a bladder? I understand the fiberglass burns a lot faster, but the fire would still start in a steel bodied car.
Old May 10, 2008 | 09:05 AM
tjohn1008's Avatar
tjohn1008
thanks for all your input,i think i will install in new tank,tj.
Old May 10, 2008 | 10:42 AM
Jud Chapin's Avatar
Jud Chapin
On a plane about 30 years ago, I happened to be sitting next to a Fed who was very familiar with this bladder and why the Gov got involved. While I don't remember even how the subject came up, as I recall, it was an extreme safety issue since a rear end or side collision could result in a punctured fuel tank, which could result in fuel all over the place, which could result in a fire, and burn the Vette, and its occupants, to the ground in a very short few minutes. Other factors were, I believe, the proximity of the tank to external elements and the size of the car. One thing I remember very clearly was that this guy was very adamant about the safety provided by the bladder. Frankly, there is no way I run my Vette without one.
Here's something I found on the net regarding the subject. Tab down to General Motors, Exploding Gas Tanks:
http://www.multinationalmonitor.org/...mm1292_06.html
To bladder or no bladder?
