Checking the Washer Motor
Old May 8, 2008 | 07:38 PM
BigJim13 JR.'s Avatar
BigJim13 JR.
Default Checking the Washer Motor
HI,
i have 2 wiper motors but i dont know if either of them work. is there a way to bench check them? i have a 12 volt transformer but dont know what needs to be hooked up to run the motor
has anybody tried this or know of a way to check it ourside of the car? i dont have anything in the inteiror conected so cant really put it back in teh car to test it at the present time
Old May 8, 2008 | 08:02 PM
LYLE's Avatar
LYLE
I set up to test motors and washers once and used the switch from the dash and the wiring diagram. It took too many wires to remember.
Old May 8, 2008 | 09:12 PM
GaryS's Avatar
GaryS
Knowing the year might be helpful.
Old May 8, 2008 | 09:20 PM
'75's Avatar
'75
Ground to the body,positive to the center terminal, then ground the top terminal for 1 speed or ground the bottom terninal for the other speed. Remove ground from top or bottom terminals and the motor should park.
Old May 8, 2008 | 10:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This page will tell you how to test the motor if it's 1963-1967 1969-1982. The wire colors may be different since it was done for a 1969-1972
http://willcoxcorvette.com/repairand...elp.php?hID=95
Old May 16, 2008 | 02:18 PM
BigJim13 JR.
thanks for all the replys! i will try the wilcox method. however, would this theoretically work to test the wiper motor itself
I pulled out the motor to clean and regrease the inside of the unit and shaved 1/8" off the wire sheathing to expose the wires and then bypassing everything else, tried to run the motor w/ a 12 volt transformer. It did not work. do i really learn anything by doing this?
Old May 16, 2008 | 11:16 PM
0Willcox Corvette
Former Vendor
Yes if you follow the test you can do this on a bench without any problems.
Old May 17, 2008 | 10:11 AM
'75's Avatar
'75
Your transformer is probably not making enough power to test the wiper motor. You should use a 12 volt battery.
To Checking the Washer Motor
