engine won't start
Old May 9, 2008 | 02:44 PM
V-Rod's Avatar
V-Rod
Default engine won't start
After starting engine for the first time since receiving it from builder last night today will not start. I had to put a throttle spring on it and think I have it flooded. cause I smell a lot of gas after each attempt. how long should it take to clear out? I have waited 30-45 min between attempts and do not give fuel when first turnning over then give 2 pumps and try again but engine does not fire. any suggestions would like to get it to muffer shop today Thanks
PS how did temp gauge work on 78?
Old May 9, 2008 | 02:50 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Try holding the pedal to the floor when starting. This is generally the method used to start a flooded engine. Don't pump it, however.
Old May 9, 2008 | 03:33 PM
wiseman79's Avatar
wiseman79
If you severely flooded it you may need to check the plugs.
Old May 9, 2008 | 03:39 PM
V-Rod's Avatar
V-Rod
Thanks Jud,
Have use that method before and that is the way we used to start flooded radial aircraft engines. haven't tried that yet partly because I broke the plastic clip that holds the throttle cable to peddle but will get wife to turn engine over and I will work throttle out side
Old May 9, 2008 | 03:45 PM
V-Rod's Avatar
V-Rod
check plugs for fowlling? look for black conductors?
Old May 9, 2008 | 04:26 PM
Jud Chapin's Avatar
Jud Chapin
Originally Posted by V-Rod
Thanks Jud,
You're welcome, and yes, I have done it that way. Quoting my '76 Vette owners manual regarding "Engine Flooded" the instructions are as follows: "Depress accelerator pedal and hold to floor while starting until engine is cleared of excess fuel and is running smoothly. Never pump the accelerator pedal". Hope this helps.
Old May 9, 2008 | 06:26 PM
V-Rod's Avatar
V-Rod
I tried flood starting it several time with no luck. I also pull a plug and it looked ok to me dark but not crusty it did not look wet any other suggestions?
Old May 9, 2008 | 06:38 PM
Oldguard 7's Avatar
Oldguard 7
Does it crank but not start? Check your ignition system. Is the distributor installed correctly, Is the ground strap from the starter that atatches to the frame's connection clean and tight? The ground strap is the big thick wire running from the starter and attatches to the bottom of the frame. Is the ignition wire connected to the coil on the distributor? I'm sure others will throw possibilities your way.
Old May 9, 2008 | 06:53 PM
V-Rod's Avatar
V-Rod
It started an ran last night. I did not run it long just a few min. about three times. To day it turns over but will not start has not fired 1 time. I have not tried to check MDS system yet today, but when I do where is good place to start
Old May 9, 2008 | 08:56 PM
blue427's Avatar
blue427
I would pull the plugs and keep them out for a few hours at least,dry your plugs by hand and ckeck the oil for gas,you can wipe an engine out with gas in the oil,change oil if needed. Then retry starting normaly. good luck.
To engine won't start
