78 Differential Code
May 9, 2008 | 10:28 PM
I found the following stamped on the differential in a 78 pace car.
Can someone identify the ratio and such?
OK 110 W8E1 or EI
Thank you,
Verle
May 9, 2008 | 11:35 PM
NCM Grand Opening Veteran
St. Jude Donor '11, '17
May 10, 2008 | 05:11 AM
Quote:
Originally Posted by
verle
OK 110 W8E1 or EI
I agree with Rat...OK is the 3:08 posi code.
110 = is a julian date code; W = is the Warren assembly plan; 8 = year of production; and E = Eaton is the posi manufacturer.
so your differential was assemblied by the Warren plant on the 110th day of 1978 or approximately a late April 1978 manufactured differential.
May 10, 2008 | 07:44 PM
Thank you for the quick information.
I appreciate it.
Verle
May 11, 2008 | 05:06 AM
verle
It's the big check it get!
1978 ,
78 ,
code ,
codes ,
corvette ,
differential ,
differentials ,
end ,
engine ,
manufactured ,
rear ,
stamp ,
w8e1
