Mufflers ?????
Old May 10, 2008 | 12:50 AM
WHOOOOME's Avatar
WHOOOOME
Default Mufflers ?????
What are the LEAST restrictive mufflers available for the Hooker 4" diameter sidepipes???
Old May 10, 2008 | 07:55 AM
69ttop502's Avatar
69ttop502
In my experience, which includes 3 different dyno sessions, the STS baffles are hands down the best. Do a search and you can read for days on this one. How much motor do you have?
Bill
Old May 10, 2008 | 05:08 PM
WHOOOOME's Avatar
WHOOOOME
Bill
a little under 600hp at the flywheel (580+/-)
Old May 10, 2008 | 06:22 PM
randommj's Avatar
randommj
I use sweet thunder, but I went to their web site to give you today and all their product are diffrent, Id expect them to have new products, but I cant even find the ones I have, sorry
but if their new ones are anything like their old ones then they are very un-restricted!!!
Miles
Old May 10, 2008 | 07:06 PM
randommj's Avatar
randommj
AHH here we go! this is what I run
the ears ring after getting off the highway though
http://www.sweet-thunder.com/chamber..._corvette.html
I got the larger outta the 3 choices 2.5 inch
Miles
Old May 10, 2008 | 07:36 PM
ironarms's Avatar
ironarms
St. Jude Donor '05-'08-'09
I liked the STS spiral baffles
Old May 10, 2008 | 07:45 PM
69ttop502's Avatar
69ttop502
You have a motor similar to mine as I am at 614 at the flywheel. In my dyno work, anything 2.5 inches in diameter posed a huge restriction. The area of the baffles uncapped is over 3 inches. Someone a few years ago calculated the actual area. I think you would definitely need to run the baffles uncapped with your motor to not pose any restriction. They sound great as well. I can't comment on any of the newest mufflers like the sweet thunders or the max flows, but I did test a similar muffler called a Loback which was a 2.5 inch insert without louvres protuding into the flow and it was a huge restriction. My engine builder said that at my hp level and rpm potential, even a 3 inch would pose a restriction.
Bill
Old May 11, 2008 | 12:15 AM
WHOOOOME's Avatar
WHOOOOME
STS seems to be the way to go. I checked out the website.
To Mufflers ?????
