Who's actually right?
Old May 10, 2008 | 06:11 AM
Five-spot's Avatar
Five-spot
Default Who's actually right?
The previous owner of my 75 coupe pulled the original L-48 and replaced it with a GMPP crate engine(part #12486041) the original spec sheet reccomends R43LTS spark plugs. No auto parts store in my area has ever heard of this#. I contacted AC-Delco online to find a source and they advised that this is the wrong plug and the one I need is actually the R-44TX. Anybody got a clue whats up with this, 'cause these are two completely different plugs?
Old May 10, 2008 | 06:50 PM
enkeivette's Avatar
enkeivette
They prob don't make them anymore. Just guessing here, but it seems to me that the 44s would be a hotter plug than the orig 43s. If you're worried try running a R-43TX. It's not a big deal, if it were a monster powerplant on the verge of detonation you should be worried. But with a tame crate engine any plugs meant for a carb SBC will do fine.
Old May 10, 2008 | 07:00 PM
Speed Hound's Avatar
0Speed Hound
Former Vendor
I agree. Without knowing Delcos numbering, I'd venture a strong guess that the 44 is indeed only one step hotter than the 43. Shouldn't be a big deal on that engine to run either plug.
Old May 10, 2008 | 08:28 PM
BarryK's Avatar
BarryK
AC no longer makes the AC44 plug. When it was dropped most reference books indicate the AC43 as the replacement but the R43 is typically too cold of a plug for the street and tends to foul a lot.
The popular replacement is the AC45 which is a hotter plug and tends to do better than the AC43.
As for the "R" designation, that says it's a resistor type plug which was not stock on the older motors, they used resistor type ignition wires. As more and more electronics were added to vehicles they went to a resistor type plug to help keep electrical interference down. In your car it doesn't really matter much if you run a resistor or non-resistor type plug. Ask different people and you will get different opinions on the resistor or non-resistor type plugs. I've run both on my '65. It always had AC-R45's when I got the car and I continued to use them until I redid the engine bay and somehow developed a high-rpm miss that I couldn't get to go away until someone recommended using the non-resistor plugs - he swore it would help because of the added resistance of both the original resistor ignition wires and than a resistor type plug (the non-original R45's) would reduce the current so I tried them the non-resistor type and it seemed to help.
Alternatives to the AC45 (non-resistor type plugs) are also the NGK B4 and Denso W14-U
Old May 11, 2008 | 10:10 AM
MITGS's Avatar
MITGS
I am not trying to confuse the issue but is that the same plug recommendde for a ZZ4 crate motor? I have had problems finding the cross-reference info for the ZZ4 service items like plugs and filters.
Old May 12, 2008 | 01:57 PM
Jay-Dog's Avatar
Jay-Dog
Indeed, 43 indicates a colder plug than 44 or 45. The question I would have if I were you is what does the X mean? You'll want to verify the seal style and the reach. The plugs required on my stock 76 heads are TS (tapered Seal).
Old May 12, 2008 | 10:45 PM
Five-spot's Avatar
Five-spot
Tapered seat, extra long reach
Old May 13, 2008 | 07:50 AM
Paul L's Avatar
Paul L
My guess is that S is extended tip and X is extra long reach.
http://www.acdelco.com/parts/sparkpl...tification.jsp
Old May 13, 2008 | 10:47 PM
rays71's Avatar
rays71
New R44TX AC spark plugs on ebay now. take care
Old Sep 29, 2010 | 10:34 AM
TeaEye's Avatar
TeaEye
They are also available on Summit Racing!
http://www.summitracing.com/parts/ACF-R44TX/
Still can't figure out whatthe X in TX means.
Look at the Delco site below
http://www.acdelco.com/parts/spark-p...tification.jsp
Old Sep 29, 2010 | 11:55 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I believe the heads on the ZZ4 use the same plug as the late 80's corvettes. Personally I found my best results using the Marine plugs that came in my zz4. They were MR43LTS.
To Who's actually right?
