vacum source
Old May 11, 2008 | 07:29 AM
Tina69's Avatar
Tina69
Default vacum source
Finished build and running well. I have a 4150 hollley on an air gap rpm and the carb bowls cover the manifold vacum which I plugged. If I put a spacer in, there will be a clearance problem I think. I need a vacum source and I am using the carb source for pcv. any suggestions? I only need enough vacum for accessories, no power brakes. Any input is greatly appreciated.
Old May 11, 2008 | 09:14 AM
BarryK's Avatar
BarryK
you could always drill and tap another hole in the intake for vacuum. The fittings are available from most of the major parts vendors to than connect your vacuum lines.
Old May 11, 2008 | 09:39 AM
Tina69's Avatar
Tina69
just found a low profile fitting from edelbrock that says it will clear fuel bowls. We will soon find out!!!!
To vacum source
