75 Q-jet issues
Old May 11, 2008 | 08:17 PM
DINO XANTHAKYS's Avatar
DINO XANTHAKYS
Default 75 Q-jet issues
My carb has been acting up, The engine is backfiring on decel; When I get on it, it feels sluggish and boggs. Has anyone tried a direct replacement carb and ifso how do you like it and which one did you get, or do you recommend sending it to Lars for a rebuild. If you recomend Lars, how would I get in contact wih him?
Dino
Old May 11, 2008 | 09:02 PM
BigBlockk's Avatar
BigBlockk
It sounds like it is leaning out. This could be nothing more that a little dirt gumming up the works or a vacuum leak. Check all the vacuum hoses and connections for leaks. If you're comfortable with it, remove the carburetor from the engine and take the top off. Get some carburetor cleaner in all of the fuel inlet and passages to clean them out. Make sure the air bleeds are clean. Make sure the power piston is free in its bore. Record the jet/rod combo.
Report back.
BigBlockk
Later.....
Old May 11, 2008 | 09:25 PM
a1sensei's Avatar
a1sensei
Lars: v8fastcars@msn.com
To 75 Q-jet issues
