Dyno pull tie-down areas
Old May 11, 2008 | 10:01 PM
Hadez's Avatar
Hadez
Default Dyno pull tie-down areas
where do you guys have them tie down our vettes when they do the dyno pulls? I am going to get one done and want to make sure it ain't going any place when they do the dyno pulls
Old May 12, 2008 | 11:37 AM
Hadez's Avatar
Hadez
bump...anybody got some comments on where to tie down the chasis when I do some dyno pulls?
Old May 12, 2008 | 02:02 PM
gkull's Avatar
gkull
I used 6 straps. The dyno shop had a rack of various types. Two on the rear most cross member going aft. two on the cross member just in front of the differential, pulling down and forward. one on each A-Arm outside of the spring tied aft
Old May 12, 2008 | 03:45 PM
Hadez's Avatar
Hadez
what about the 2 holes used in the very front frame crossmember when towing onto a flat bed?
is the a-arms a good idea since many people say not to wrap a tow strap to them when going onto a flat bed?
Old May 13, 2008 | 08:38 AM
gkull's Avatar
gkull
I did not worry about it. Your car nose will want to rise when you apply power to the drum. I dyno tuned an engine combo years ago. So it spent allot of time at all kinds of rpm with exhaust sniffers.
To Dyno pull tie-down areas
