Battery drain
Old May 13, 2008 | 09:52 AM
RAGTOP75's Avatar
RAGTOP75
Default Battery drain
Hi, I've had an on-going problem with battery drain and so now I'm going to attack this issue in another way. I did remove the fuses and checked the current with a multimeter and got notheing conclusive to hold on to. Here goes...I believe that with the car off and all of the switches off that there should be no drain thru fused curcuits. I'm thinking that the drain is in the wires that are always hot...like the headlites...starter...alternator..cig liter etc. Does anyone know what wires are supposed to be hot when the car is off? I have a 1975 Roadster. Me thinks that I should start over in these areas...yes...no?
