Horsepower Upgrade ???
Old May 11, 2008 | 11:42 PM
RxForPain's Avatar
RxForPain
Default Horsepower Upgrade ???
I have a pretty much stock 71 coupe with the original 270hp/350 and TH400.
I would like to bump the horsepower up to 300 or 350 while keeping the stock appearance. Not sure what route I should take and keep the price tag within reason. I would appreciate any recommendations.
Again I want to keep the stock appearance (willing to go with 68-70 intakes, heads, carbs, or other ) without any aftermarket components.
Old May 12, 2008 | 07:52 AM
Durango_Boy's Avatar
Durango_Boy
Staying stock and respecting CA smog rules you're going to have a hard time getting your HP numbers.
You can change internal components, like maybe even a stroker kit, and have the heads done by a machine shop...or bump the compression with different pistons, decking, gaskets, and a cam and lifter swap.
Old May 12, 2008 | 10:21 PM
RxForPain's Avatar
RxForPain
At this point I don't have to worry about California smog, because of the age of the car.
Old May 12, 2008 | 10:28 PM
CorvetteDave01's Avatar
CorvetteDave01
If your planning to upgrade the crank, rods and pistons, definitely look at a 383 or preferably a 396 stroker kit imo.
To Horsepower Upgrade ???
