chaining the coil spring for removal
Old May 12, 2008 | 03:36 PM
MN-Brent's Avatar
MN-Brent
Default chaining the coil spring for removal
If I use the Lars method, floor jack under lower control arm, engine still in car, I'd like to put a chain on the spring for a little security.
Whats a better tie down point for the chain, to the upper or lower control arm?
I plan to cut 1/2 coil and reinstall original.
I'll take any tips on this one. Im pretty technically confident, but coil springs can be spooky. Also ordered the Van Steel vid
Brent.
Old May 12, 2008 | 03:49 PM
nate99's Avatar
nate99
I just pulled one side of my front suspension apart. I just got the ball joint disconnected from the UCA with the jack under the LCA and eased it down slowly with no drama at all.
While I've done a few like this before without, a chain would probably be a good idea.
Could you loop it around the frame?
Old May 12, 2008 | 03:52 PM
hugie82's Avatar
hugie82
Same here, never used the chain method but too be safe throw a strap or chain around either one upper or lower
Old May 12, 2008 | 03:55 PM
Gordonm's Avatar
Gordonm
Are these original or aftermarket springs. I have never had to use anything with the aftermarket springs. The yare much shorter tha nthe originals and don't need to be chained or secured. They will fall out when you have the control arm about half way down. It they are original your best bet is to put them in the garbage and start with a good set of springs.
Old May 12, 2008 | 04:05 PM
MN-Brent's Avatar
MN-Brent
Yep, 460s and 550s are shorter, uncompressed.
This will be an OEM FE7 spring for an 82, which I believe is the same spring as a non FE7 for 82.
So the OEM springs will allow you to fully disengage with the control arms still bolted to the frame and just the upper ball joint loose?
Old May 12, 2008 | 04:19 PM
nate99's Avatar
nate99
They did on my '81 with no problem, just make sure that you have the car high enough in the air to not trap your floor jack and release the jack as slowly as you can.
Old May 12, 2008 | 04:47 PM
The Spark's Avatar
The Spark
I run some all-thread through the upper shock mount, down through the spring and then out the LCA. I have a piece of round plate that is larger than the hole in the LCA. I put nuts on top and bottom of all-thread (most of the thread sticking out the top). After loosening the ball joint(s), I lower the LCA by turning the upper nut.
I installed my new springs by tightening the upper nut and pulling the LCA up into place.
I didn't have the engine in my car at the time so the jack-under-the-LCA method would not work for me. It just lifted the car.
Since you have the engine weight you could use the all-thread as a safety precaution.
Old May 12, 2008 | 05:01 PM
Theiskell's Avatar
Theiskell
Where were you about a week ago I just replaced my lower a arm bushings with the motor out. What a PIA… I put my whole family and a friend in the engine compartment to get enough weight to collapse the spring. I will remember the all thread trick if I ever need to do it again.
Old May 12, 2008 | 05:12 PM
nate99's Avatar
nate99
Now you really needed to get a pic of that.
Old May 12, 2008 | 05:30 PM
Theiskell's Avatar
Theiskell
it was funny
Old May 12, 2008 | 06:02 PM
nate99's Avatar
nate99
All this spring compressor talk has convinced me to buy some shorter/heavier rate replacements.
That and the fact that the steel on the stockers looked about like that of the grate on that old BBQ grill that you've been meaning to throw out for the past four years.
Old May 12, 2008 | 06:03 PM
mrvette's Avatar
mrvette
it was funny
what you really needed do is take a chain/come along and tie the floor jack wheels to the frame....then jack it off.....
Old May 12, 2008 | 08:04 PM
GPGG70's Avatar
GPGG70
I'm glad I read this post.
What size allthread was used. Thats a great idea.
I'm getting ready to change all the bushings on the A arms and ball joints on my 1970 with stock 350, and want to keep it close to original with the springs, however I've been reading about the aftermarket replacement springs that are not as tall and dont have to use a spring compressor, but will keep the right ride height.
What I'm thinking is the springs on the car are original and to me being 38 years old have lost there strenght and (WIIT) while I'm in there changing out everything, & now is the time to do it.
Any suggestions on replacement and or good stock spring for this car?
Thanks for any info in advance.
Old May 12, 2008 | 10:11 PM
LYLE's Avatar
LYLE
I use 5/8 theraded rod. If you want get fancy after you take the shock out use the threaded holes to hold a plate you make with a hole in the center for the threaded rod. On the top side all you need is two or three washers.
Old May 12, 2008 | 11:25 PM
Theiskell's Avatar
Theiskell
All I can say is get ready for some work. Changing the bushings and ball joints is the biggest PIA I have found so far. It’s not so bad getting the arms out and back in the real fun starts when you start trying to get the bushings out. I had to use a propane torch and heat the arm up around the bushing. I have a full size press and mine were in so tight it wanted to bend the A arm before the bushing would start moving.
Old May 13, 2008 | 07:55 AM
nate99's Avatar
nate99
I'm tracking my fun with the front suspension on my '81 in this thread, and as mentioned before, the stock springs are problematic when it comes to reinstallation due to their uncompressed height. I just ordered a set from Zip's that are supposed to retain stock ride height, but are physically shorter (and easier to install), and have a firmer ride.
If you are going to do bushings and ball joints, you will have to remove the springs anyway, it would be a shame to do all of that work and then have one of them break, or just continue to wear out and further affect your handling.
Old May 13, 2008 | 10:13 AM
71rdster's Avatar
71rdster
That sounds just like my spring installation tool.
To chaining the coil spring for removal
Old May 13, 2008 | 12:26 PM
Wuttin's Avatar
Wuttin
Some guys use a spare pulley...fits really nice in the LCA and keeps you from making a custom plate.
Old May 13, 2008 | 01:05 PM
Scott Marzahl's Avatar
Scott Marzahl
I used to use 5/8" threaded rod as well, but even better is ACME threaded rod, larger threads make for easier turning on the nut.
Old May 13, 2008 | 02:12 PM
redman76's Avatar
redman76
St. Jude Donor '09
I like the althread suggestion too. When I replaced my bushings, tie-rods and ball joints, getting them out and replacing was the easy part. Getting that stock spring to compress was a PIA. I was using spring compressors and had to keep taking off / putting on to get them to line up just right when putting back together. That was a lot of effort and trial and error. Now I'm thinking of cutting coils to lower frontend, but dreaded doing the process again. The althread sounds much easier and can get right the first time. Thanks for the suggestion
Oh, BTW, I did wrap a chain around the LCA for safety!!!
