What is this interior part?
Old May 13, 2008 | 02:46 PM
nvvetgirl's Avatar
nvvetgirl
Default What is this interior part?
I have removed the defective AC unit and heater blower and there is a round metal piece that looks alot like a vacuum headlight actuator (only smaller) under the passenger side kick panel. It has a small rubber hose going to the heater control switch (I think). Two questions: what is it? Can I get rid of it? This car will be a race car only and not a street car.
Old May 13, 2008 | 02:51 PM
Binnie77's Avatar
Binnie77
That is a vaccum control that opens a door when your A/C is on high. You no longer need to worry about it if you have removed the A/C...just plug the vacuum line going to it.
Old May 13, 2008 | 02:52 PM
vettfixr's Avatar
vettfixr
The part you are talking about is a vacuum actuator that operates a flap in the kickpanel. This allows air to recirculate from the cabin through the AC unit. If you don't have AC in the car you can remove the vacuum actuator.
Old May 13, 2008 | 04:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a picture and how it operates.
http://willcoxcorvette.com/instructi...k_cut_away.pdf
Old May 13, 2008 | 10:39 PM
nvvetgirl's Avatar
nvvetgirl
Default What is this part?
Thank you. Thank you. Thank you.
Old May 14, 2008 | 05:47 PM
wattac2's Avatar
wattac2
Default Rear Vent if you DON'T have AC
Not sure how "unsafe" this is, but the rear vents are controlled by a similar actuator to open/close the vent for the passenger compartment if the car did NOT have AC. If the car had AC the vent was sealed shut and the actuator removed.
Just an FYI if interested.
Andy
To What is this interior part?
