engine dropping out
Old May 14, 2008 | 10:31 AM
terrible_buddhist's Avatar
terrible_buddhist
Default engine dropping out
kind of weird...I will be cruising along and the rpms will just drop out for a split second...then just keep going.
any thoughts?
Old May 14, 2008 | 10:39 AM
greg454's Avatar
greg454
sounds like a clogged fuel filter.
Old May 14, 2008 | 11:30 AM
TedH's Avatar
TedH
any thoughts?
Any chance a distro wire is loose? If you have HEI and one of the wires to the distro is loose, it could be the problem. I'm thinking it would be the wire to the coil or module.
Old May 14, 2008 | 11:59 AM
terrible_buddhist
sorry, its a 68 427 with points.
Old May 14, 2008 | 12:03 PM
DIPPOLD's Avatar
DIPPOLD
I am going to tell you about a funny story that just happened to me this am. I was cruizing on the highway and the engine seemed to surge off and on. Got off the highway onto a local road to check it out and heard this knocking, sounded like a rod. Opened the hood and saw the steel braded line from the fuel pump to the carb moving back and forth, went around to the other side and saw the fuel pump moving in and out. The bolts for the pump were gone. Engine still ran however it seemed to surge on and off. Currently in the a local shop getting the new gaskets and bolts. WITH thread locker. LOL So check the fuel pump.
To engine dropping out
