oil in rear compartment
Old May 14, 2008 | 11:29 PM
LanceB's Avatar
LanceB
Default oil in rear compartment
I wipe it up it comes back. I noticed a small crack on the inner wall of the rear passenger compartment and some type of oil or fluid seems to be creeping through. I am having trouble figuring out what could be causing that and what components are directly under it. It is the passenger compartment where the jack is stored. The rear differential is under this and I suspect the culprit(gulp). I don't know if any brake lines run in this area. Hopefully I can get it on jacks or take inner compartment to pieces to see whats going on in the next couple of days. It sure looks greasy in the rear area underneath. I will try to identify the fluid better next time I see it too. Any ideas?
Old May 15, 2008 | 12:15 AM
Ron R's Avatar
Ron R
I'm not quite sure how the rear differential would be slinging oil upward through a little crack in the compartment... are you sure it's not just your jack leaking fluid?
Old May 15, 2008 | 12:27 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Differential fluid is thick and has a distinct odor.
Old May 15, 2008 | 07:55 AM
Durango_Boy's Avatar
Durango_Boy
Engine or transmission oil can easily blow back and under the carriage of the car, soaking everything. It would not surprise me if you have an oil leak and when you drive it saturates the storage compartment, where it seeps in through the crack.
Old May 15, 2008 | 08:24 AM
gingerbreadman1977's Avatar
gingerbreadman1977
if you have an oil leak big enough to get into that compartment through that hole in the bottom then surely it must be on your floor in the garage as well when u park up. i say if you dont then i agree with ron about the jack make a mess.
Old May 15, 2008 | 09:10 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Before I would do anything, I'd take a look under the car and see if the underneath area near the pax compartment is wet with some type of car fluid. If so, you should easily be able to isolate the source. If it is not wet, I suspect something is going on in the jack compartment.
Old May 15, 2008 | 09:26 AM
7T1vette's Avatar
7T1vette
Wipe it with your finger and smell it. If it has a strong, pungent odor, it is probably differential lube. That wouldn't be on your garage floor because it probably doesn't leak if the driveshaft is not turning (at significant RPM). That being the case, the front seal is probably worn out and needs to be replaced. You can do so by dropping the driveshaft from the diffy yoke, removing that yoke, popping out the seal and replacing it, and reinstalling yoke and driveshaft. There are some details that you need to take care of during this procedure, so follow directions of GM Service/Overhaul manual to do it correctly.
Old May 15, 2008 | 11:40 AM
LanceB's Avatar
LanceB
Thanks for all of the advice. There really isn't anything significant on the floor from what I can tell. I am putting new cardboard under it to see what new leaks I might notice (because there is always something leaking that I am fixing). I just cleaned out the compartment and I used to store oil in it. I cleaned it out and when I saw this last night I wiped it up and threw the towel away before I realized the oil shouldn't be there. Definitely isn't coming from the jack. I wonder what could have caused the crack in the compartment?
Old May 15, 2008 | 03:10 PM
C3 4ME's Avatar
C3 4ME
I would leave the jack out for a while and see. I really don't see how it could easily do it, but my money is on the pinion seal on the differential.
Old May 15, 2008 | 03:29 PM
GTR1999's Avatar
GTR1999
If it's the pinion seal you're going to see it under the car. They leak on the snubber and exhaust. You won't mistake the smell as well.
To oil in rear compartment
