Water pump
Old May 15, 2008 | 05:27 PM
kmobrien76's Avatar
kmobrien76
Default Water pump
So my wp is leaking, I went to my local parts store, the guy says there's two listed, one for the car with "heat" and one without...So I said well I have heat and we ordered that one, anyone have a clue what he's talking about? I don't want to get it to the shop, have them pull it, find out it's the wrong one...
Kevin
Old May 15, 2008 | 05:38 PM
Durango_Boy's Avatar
Durango_Boy
Car's with heat, have a heater core, and need a nipple on the water pump for a heater hose that goes to the heater core. A non-heat car would probably not have that nipple.
Old May 15, 2008 | 07:17 PM
Dantana's Avatar
Dantana
Bingo DB.
Old May 15, 2008 | 07:29 PM
kmobrien76's Avatar
kmobrien76
So is it safe to assume that by ordering the one for a car with heat and that I have heat it's the right one? Don't all 74's have heat? Don't all Vette's have heat???
Thanks,
Kevin
Old May 15, 2008 | 07:44 PM
BarryK's Avatar
BarryK
you got the short neck pump didn't you?
Old May 15, 2008 | 07:50 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Be careful because there are two different "short neck" water pumps. The one that has the 3/4 inch shaft is about 1/8 inch longer than the one which has a 5/8 inch shaft. Get the wrong one and you'll have belt alignment problems as well as fan clutch hub fit problems.
Old May 15, 2008 | 07:59 PM
kmobrien76's Avatar
kmobrien76
The way they're explaining it to me is that one is made that has an outlet to a heater core and one that doesn't have that....I ordered the one with...hmmm...
Kevin
Old May 15, 2008 | 08:33 PM
kmobrien76's Avatar
kmobrien76
LarryWalk,
I just looked through Mid-America's catalogue (pg 132) the 55-70's have the 5/8" shaft & the 71-82 have the 3/4", I called the shop where I ordered from and it's the 3/4" so I'm going to roll the dice and believe that it's the right one...thanks for the heads up though!
Kevin
To Water pump
