1978 horn problems
Old May 16, 2008 | 12:35 PM
mikeymc's Avatar
mikeymc
2nd Gear
Default 1978 horn problems
I am having a problem getting the horn to work on my 1978 vette.
This is what I know so far:
The horns, relay and wiring into the steering column all work. Its once in the column the problem seems to be. I have installed a new horn contact, spring retainer etc. I have power in the column, there is a ring with 3 brass contacts on it. On top of the contacts is an piece of plastic/foam to act as an insulator from the coil spring that goes up to the lower horn contact ring. It looks as if i may be missing a piece. Does anybody have an exploded view of all the column components. I have Haynes, GM workshop manual and numerour after market parts catalogs but cannot get anything that seems to help.
Any feedback will be graetly appreciated.
Mike
Old May 16, 2008 | 02:07 PM
rihwoods's Avatar
rihwoods
What year...??
http://www.corvetteforum.net/c3/tune.../index20.shtml
Old May 16, 2008 | 05:56 PM
Duke94's Avatar
Duke94
You'll find it here about half way down.
http://jimshea.corvettefaq.com/?page_id=4
Old May 17, 2008 | 05:11 AM
hunt4cleanair's Avatar
hunt4cleanair
To 1978 horn problems
