Brakes Locking UP
Old May 18, 2008 | 02:24 PM
WANNA69's Avatar
WANNA69
7th Gear
Default Brakes Locking UP
I recently bought my first vette, a 69 convertible. Every time I have driven it the brakes lock up & will not release. I have to loosen the fittings to the master cylinder & bleed pressure to get the front & rear brakes to release. It takes 10-15 min., just enough time for it to get warmed up, for the brakes to lock up. I replaced the master cylinder & bled the entire system. The power brakes were added about three years ago. The previous owner told me the rear brakes locked up on him once, so he had the rear completely redone. Has anyone else had a similar incident? What else could it be?
Old May 18, 2008 | 02:34 PM
A88FXRS's Avatar
A88FXRS
rubber brake hoses do this when old & swell, will not allow pressure release
Old May 18, 2008 | 03:38 PM
noonie's Avatar
noonie
Only 2 things will do this.
As mentioned, the flex brake lines could bad and acting as one way check valves.
2nd, the master cylinder rod is either wrong or adjusted too long, not allowing for the master cylinder piston to return to it's normal, non activated position, and releasing pressure. This could either be between the cyl and the booster or the booster and the pedal assembly.
Old May 19, 2008 | 12:29 PM
croaker's Avatar
croaker
I had a 74 back in the eighties brakes would lock up you couldn't move the car at all turned out to be a small pinhole in the threads of the proportioning valve
Old May 19, 2008 | 10:02 PM
WANNA69's Avatar
WANNA69
7th Gear
Thanks all. This gives me a few things to track down. I appreciate the help.
To Brakes Locking UP
