As for PCV you need to tap holes in the runners and connect them to a common pipe of some sort and from there you connect to the PCV valve. On the other side is a regular breather.
Same technique for IAC and vacuum connections, as you need them for some applications.
Cruise-In IV Veteran
Cruise-In V Veteran
I dont care about PCV or the like. I am wondering how they fit under the runners.
I had been thinking about that for the vacuum system. You only really need to do one side, as dual plane intakes only pull vacuum from one side of the motor.
Looks like the pierce unit is the same as the moon one and those on ebay for 500$ and less (seen them for 400 recently)
If you want a really large manifold, check out the crossram I posted above (the one for mech FI), it has 60mm throttle blades.
Last time I checked the DC&O unit has 45mm TBs??? The moon manifold can easily be hogged out, there's plenty of meat. The only area where you have to be careful is where the runners cross each other.
