DCOE Webers
Old May 22, 2008 | 01:22 PM
  #41
ram82fire's Avatar
ram82fire
Originally Posted by Guru_4_hire
I dont think you would be violating forum rules.
The specs of YOUR motor belong to YOU. The knowledge in your head belongs to YOU.
I agree about the knowledge , but it is poor manners to discuss vendors on this forum . Just my personal feelings
gman
Old May 22, 2008 | 01:24 PM
  #42
ram82fire's Avatar
ram82fire
Nice setup you have ,,,,,,,,, it is also good to see some of these units on display here!
gman
Old May 22, 2008 | 01:47 PM
  #43
gkull's Avatar
gkull
Originally Posted by ram82fire
I They came with 36 mm chokes , a bit on the small side . I got a hold of some 40mm chokes and made a fixture and bored them to 42 mm .
This diameter change from 36mm to 42mm is something like a 33% gain in air flow. If you figure out the area of 36 mm is @1018 sq mm and 42 is @1380 sq mm.
This changes the power potential from 350 hp to close to 470 hp. More than enough to feed your typical hot rodded 350 motor from 375 hp to 430 hp
Old May 22, 2008 | 02:51 PM
  #44
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A bit off-topic, but I saw something pretty cool recently - a BMW 2002 4-banger with a pair of DCOE fuel-injection throttle bodies.
Old May 22, 2008 | 03:56 PM
  #45
V-Twin's Avatar
V-Twin
Those have been around forever, lumenition, VGS, DC&O and plenty of others make DCOE (and IFD or IDA) style TBs.
Old May 22, 2008 | 04:03 PM
  #46
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Originally Posted by lvrpool32
I'm running quad 48MM DRLA Del'lorto's with 46mm venturis, has no issues feeding my 396 small block. Tuning is a breeze if you take your time and pay attention, fuel pressure is very important.
I order most of my stuff direct from dellorto in the UK, its not that expensive (deffinately not cheap), but has crept up a little in the past year due to the weak $.
Nick
This is interesting to me because I am building a 396 small block. Whats your RPM range and cam specs if you are willing to share.
Old May 22, 2008 | 04:21 PM
  #47
lvrpool32's Avatar
lvrpool32
I am running a comp cams solid roller...have the specs at home..its in the .580 lift range...AFR 210cc heads (the new Eliminators).
The one issue with my set up is that the vintage Mackay intake has pretty long runners so more suited to low/mid range torq, so I have a sheetmetal, short runner intake I am building.
Nick
Old May 22, 2008 | 04:29 PM
  #48
Belgian1979vette's Avatar
Belgian1979vette
Originally Posted by tonyv123
Doug 61,
Here's that vacuum set-up picture you were lookin' for:
http://www.inglese.com/Products/General_Motors.asp
(Click on vacuum system)
Belgian1979'
With fuel injection, do you get as much backfire as with a Weber set-up?
The backfire has to do with the fact that you have no plenum on these types to dampen the reversion in the intake tract. So even with EFI you will get some spitting back (which is not a backfire). If you don't have something to cover the throats, you could end up with a fire (with stressing the 'could' part).
I went with EFI because I have the full 50 mm of throttle bores available to my engine. It supports a max of 640 hp at 7000 on a 350. A normal weber has a venturi that has a smaller size than the bore and it is this venturi that determines how many cfm the carb allows into the engine.
EFI with a programmable computers lets you tune the engine easier without having to deal with leaning the engine out on top or having to deal with air bleeds, ....
It's very important to get the size of the itb's correct. To big a bore will mean that a small amount of throttle opening will allow for a lot of air movement. This could mean the difference between a tunable and non-tunable engine...
Don't know about the weber, but I heard the main system only kicks in at above 3000 rpm.
Old May 22, 2008 | 04:51 PM
  #49
Guru_4_hire
Cruise-In V Veteran
Nick
I am thinking about something in the 5000 peak power, toping out at 5500rpm.
Old May 22, 2008 | 05:47 PM
  #50
blnvette's Avatar
blnvette
It works for me !
Old May 23, 2008 | 11:44 AM
  #51
Doug 61's Avatar
Doug 61
Some very nice looking setups in the pics, I like the look of the injection but its probably a bit outside of my budget. I plan on building the air cleaner setup with a single unit on each side, similar to the blue one pictured earlier. It looks like it may be a bit of a learning curve getting everything set up, but I think it will be worth the trouble. Thanks again for the input, I've learnt more here than I have from the sales guys.
Doug
Old May 23, 2008 | 12:59 PM
  #52
mxscooter's Avatar
mxscooter
Had downdrafts on my Porsche, I actually loved tuning and balancing them - I sure wish I knew you guys back then!
Sorry, nothing useful to input LOL
Old May 23, 2008 | 02:12 PM
  #53
Guru_4_hire
Cruise-In V Veteran
Is there any special things as far as camshafts you have to consider when using one of these get ups?
Old May 23, 2008 | 04:25 PM
  #54
Belgian1979vette
Overlap should be reduced, since there is no plenum to dampen the reversion in the intake. See also the spitback comments.
Old May 23, 2008 | 04:43 PM
  #55
Guru_4_hire
Cruise-In V Veteran
OK that makes sense.
Old May 23, 2008 | 05:18 PM
  #56
cajos's Avatar
cajos
I can't get enough. More PIC's please!!
Old May 23, 2008 | 06:37 PM
  #57
roscobbc's Avatar
roscobbc
Has any one vids & sound clips of unfiltered DCOE'e on a BBC (or SBC)?
One of the nicest sounds in the world is a four pot early twin cam Lotus or Alfa sans filters.
To DCOE Webers
Old May 24, 2008 | 01:11 PM
  #58
Guru_4_hire
Cruise-In V Veteran
Since I get bored, I started thinking about my own DCOE get up.
I figure I would need somewhere between a 40-44mm venturi, in a DCOE 48mm body.
That should feed a mild 396 small block all day and then some.
Old May 24, 2008 | 06:43 PM
  #59
Belgian1979vette
http://www.youtube.com/watch?v=jfu6pHDptow
Old May 24, 2008 | 07:02 PM
  #60
Guru_4_hire
Cruise-In V Veteran
I have a dumb question.
With the DCOE intake, what are you guys doing about the breathers on the valve covers?
