control arm threadlocker?
Old May 20, 2008 | 10:47 PM
MN-Brent's Avatar
MN-Brent
Default control arm threadlocker?
Should I be using a threadlocker (blue or red) on the front suspension control arm to frame nuts & bolts?
Old May 20, 2008 | 11:34 PM
lr172's Avatar
lr172
No threadlocker necessary with Rubber bushings. I did my poly's without threadlocker and they started backing out after only a few miles. I wouldn't consider anything but red. by sure to clean the threads, including the female threads. I used laquer thinner with lots of Q tips. I don't know how will it will hold, as I just did it.
Old May 21, 2008 | 09:31 PM
MN-Brent's Avatar
MN-Brent
Im referring to the control arm shafts to frame bolts.
I think your talking about the bushing lock screws at the ends of the shafts-where if you have poly bushings, you would use red locktite.
Anyone?
Old May 21, 2008 | 10:15 PM
Jim_Harrison's Avatar
Jim_Harrison
I use it on anthing that needs to stay tight for a long time, supension parts included.
Old May 21, 2008 | 10:20 PM
SmokinBBC's Avatar
SmokinBBC
I don't. Upper ones need to be loosened for front end alignment shims.
Old May 21, 2008 | 11:09 PM
lr172's Avatar
lr172
Anyone?
I don't believe so. Bolts assembled with that much torque rarely require lock-tite unless there is some type of force trying to unscrew them or there is a heavy vibration.
Old May 21, 2008 | 11:19 PM
Racer11's Avatar
Racer11
I used grade 8 nylon lock nuts,,,,they stay.
Red is for permanent use and usually needs heat to get it to break loose,,blue will do just fine but clean threads is a must.
Old May 22, 2008 | 12:09 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Not needed.
Old May 22, 2008 | 08:27 AM
MN-Brent's Avatar
MN-Brent
Alright guys-thanks. No locktite and I used rubber bushings-not that that makes any effect for the frame bolts.
I was amazed when I pulled the lower CA bolts out, the heads were dirty but the bolts themselves and all the threads looked brand new, like the day they were put in. Something to be said about a Southwestern car. My car spent its first 20 years in Anahiem Ca.
Brent..
To control arm threadlocker?
