Here is a picture of my new swar bar. I have looked in the AIM but these bushings are not flat on both sides like the originals were.
Can anyone confirm that this is the correct way to install the bushings and stuff? Also, the sway bar has a slight angle at the end link connections, does this angle point down or up?
The bar may only fit one way, depending on how it's bent. If it could go either way, you want the end tab to be perpendicular to the bolt. Many do not end up purpendicular, so you just end up with the best fit you can get.
