Gravity Bleading Tip
Old May 21, 2008 | 12:03 PM
jimbo1972's Avatar
jimbo1972
Default Gravity Bleading Tip
I just got finished bleeding my brakes in the old 77' and everytime I have ever gravity bleed the lines, it takes for ever.
This time, I had a I had gotten a syringe from the local pharmacy. Its a big one and have no idea what its used for. I basically used it to prime the lines by hooking to the bleeder with a short hose and using it to suck the fluid down the line from the master cylinder. It took about 2 minutes to get fluid to the new caliper and then let it gravity bleed from there. That took another 5 minutes and it worked great.
Just wanted to share this little tip with you guys.
Hope it helps someone!
Jimbo
Old May 21, 2008 | 03:47 PM
WillEE's Avatar
WillEE
Good TIp - maybe I'll give gravity bleeding another chance using your method cause I tried it per SSBC's instructions years ago and found it to be a waste of time and joke. Sounds like you need to help it out a little to work within a reasonable timeframe. .
Old May 21, 2008 | 04:10 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Thanks for the tip!
Old May 21, 2008 | 05:05 PM
Alan 71's Avatar
Alan 71
That sounds like a good idea. When you say 'big'... how big do you mean? Thanks!
Regards,
Alan
Old May 21, 2008 | 05:11 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Not to be ****, but correcting the spelling to "bleed" would likely help future brake overhaulers find your great tip in a search.
Old May 21, 2008 | 05:12 PM
Oldguard 7's Avatar
Oldguard 7
Post pic please. It seems to have worked for you.
Old May 21, 2008 | 05:13 PM
Oldguard 7's Avatar
Oldguard 7
He also misspelled "syringe"
Old May 21, 2008 | 09:39 PM
jimbo1972's Avatar
jimbo1972
Sorry about the spelling and thanks for the corrections. I try not to bleed that often or use syringes!!!!
The syringe I used is plastic and about 6" long and about 1" in diameter. I cant post pics with my computer but I can take one if someone wants to post it for me.
Jimbo
Old May 21, 2008 | 11:28 PM
Racer11's Avatar
Racer11
Get at least a 100cc syringe,,,I get mine from my local Vet/farm supply store, and yea I live in the country
Old May 22, 2008 | 12:53 PM
kdf1986's Avatar
kdf1986
Thanks for the tip. I like reading the CF for this type of information.
kdf
Old May 22, 2008 | 01:58 PM
hugie82's Avatar
hugie82
It's cheaper than a hand vacuum pump GOOD TIP!
Old May 22, 2008 | 02:45 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It's all good, I was just worried that future searchers may not find a valuable piece of advice.
Old May 22, 2008 | 05:19 PM
Alan 71's Avatar
Alan 71
This is a good piece of information and so making sure people can find it is the right thing to do.
Regards,
Alan
Old May 22, 2008 | 07:26 PM
jimbo1972's Avatar
jimbo1972
I am happy that this can help! I took a pic before I put my wheels on if someone wants to post it for me. I used a 60cc Syringe. I think I it was under $1 for it at the pharmacy. I usually use it for filling the primary on my harley but I am pretty happy it worked for this.
Jimbo
To Gravity Bleading Tip
