3927186 Camel Bump
the 186 casting 2.02/1.6 were good heads 38 years ago. You are money ahead to invest in modern combustion chambers. Oh, and throw away that junk performer manifold.
They are not worth putting money into. They are 64 cc. so you get some gains in compression and valve size if they are 2.02.
the performer has such small runners that it will shut off a 350 motor at just over 5000 rpm.
in a sub 10-1 c/r motor the crane 272 with 1.6 rockers would be my choice
Valve guides - look to see if bronze guides have been installed
Valve seats - look to see if hardened inserts have been installed
Surface - make sure there's no evidence of erosion and that all mating surfaces are flat. (You may need a shop to check flatness.)
Seals and Springs - unless you know these are new or relatively new, replace them. They're not all that expensive on these old heads and if you're doing a valve job anyway it's even cheaper.
This site is worth looking at: http://www.hotrod.com/howto/51058_cy...ild/index.html
Regarding the smaller combustion chamber and improved compression ratio: This is good news if you plan to change the cam. Use one of the on-line tools to calculate dynamic compression ratios and you can start to see how improved compression ratio will let you add more cam duration which in turn allows you to add more lift. It all starts with the heads.
All that being said, I agree with others here who have suggested new heads. Unless you don't need any machining, a good set of aluminum heads is probably a much better place to start.
http://cgi.ebay.com/ebaymotors/Stain...QQcmdZViewItem
As to the intake. I had a 5.75" Victor Jr. intake (with a throttle body, not a carb) under the hood of my '76, L82 hood with a drop base air cleaner, I am guessing an Edelbrock Air gap would be a close fit with a drop base, but I would ask someone that has done it.
This is very similar to my combination. I have an Edelbrock Performer 2101 with 041 casting heads (same chambers as 186 heads, later casting), Comp Cams 268H cam and 2.5" rams horns with true 2.5" duals all the way back.
It's a very nice combination for the street and I am very happy now that it is done and built. I do have a few observations and lessons learned you might be interested in:
1. If the heads are not in good shape, you will easily spend more than they are worth in machining, that's a fact with these old units. I spent much more on my heads than a set of aluminum Brodix cost. But I now have nice cores with high quality components, and mine were fully ported when I got them.
2. Check the valve sizes. If they have the 2.02/1.60 valves, try and find out if they came from the factory with them. If not, have them checked to make wure the valves are not shrouded. This is a problem with these heads and if you don't enlarge the chamber in the correct spots, the 2.02 setups flow worse than the 1.94 setups.
3. Have the chambers cc'ed. These heads are old and could have been through a couple of machinings. Even though my chambers had been enlarged, after decking, the final cc vulume was 62cc, which is smaller than the advertised 64cc. You'll need accurate numbers to do correct static and dynamic compression calculations. Also, make sure you have the correct piston to deck measurements from your existing block, this will figure into your calcs as well.
4. Comp techs told me that they prefer a max of 9.5:1 SCR with the 268H. From my calcs, I figure that's to try and keep the DCR under 8 with iron heads. For my engine, I had to work all of the numbers backwards and compute the correct piston dish. I ended up with an exact 9.5:1 SCR and a 7.8:1 DCR when combined with a .015" thich steel shim head gasket for a quench of .041.
5. My intake ports matched perfectly with the Performer 2101 when used with a Fel-Pro 1404 intake manifold gasket. If you are using rams horn manifolds and are feeling adventurous, you can port match the heads to a Fel Pro 1444 exhaust manifold gasket, then go back and hog out the ports and runners on the rams horns to match as well. It's about 4 hrs of time to do the manifolds.
6. I can't agree more with 63mako, you are shooting for a balanced combination here, so take your time and get all of your calculations correct.
7. Don't think you can get it done in a weekend as there will be parts that will need to be ordered AFTER you make certain measurements along the way. Good example here is pushrods, after installing the cam and heads, you will need to use an adjustable pushrod length checker to make sure you get the correct rocker to valve contact patch area. With my combo, I need significantly longer pushrods. Correct valvetrain geometry will be your friend. Go fast and mess it up and you will be sorry.
8. Get the matching springs for the cam from COMP, in fact, I would suggest the whole kit that has the cam, lifters, springs, retainers, timing chain, etc. COMP will not warranty anything if you don't use their springs and lifters.
9. Take your time and really try to understand how everything interacts. Specifically, spend time on dynamic compression ratio and quench. These are two items you will find it almost impossible to correct if you have an issue. They need to be correct in your design to avoid issues. If you get these wrong, your motor might not be able to take all of the ignition it deserves for performance, and/or you might be forced to run some very expensive gas. I spent about a year re-doing my motor with a friend and it was an awesome experience. Use the forum, there are some great folks here who will help.
Good luck!
Last edited by SLVRSHRK; Jun 9, 2008 at 12:10 PM. Reason: I'm an idiot with no reading comprehension....
If those heads don't need any money thrown at them and they are ready to go and you just need to pick up a cam I say go for it!!!
